Thread: A6 Ambient Lighting Retrofit
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
  1. Re: A6 Ambient Lighting Retrofit
    #31
    Nov 2019
    Dinnington, South Yorkshire
    This is very useful thread, I look forward to trying it!
    A6 Avant 3.0 BiTDi 320ps Quattro S-Line 11/14
  2. Re: A6 Ambient Lighting Retrofit
    #32
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    I blame RGB for all this.
  3. Re: A6 Ambient Lighting Retrofit
    #33
    May 2020
    Scotland, Ayrshire
    Hi a6duke, i am a new member here. i am looking to add the ambient lighting and this post is exactly what i needed.
    did you do the centre consol as mentioned?
    if i follow the way same route to wire the leds in, will the brightness be adjusted by the dial beside the headlight switch?
    is there a way to control them via the mmi?
    Thanks in advance and great post
  4. Re: A6 Ambient Lighting Retrofit
    #34
    Jan 2010
    Yate UK
    17 Post(s)
    Quote Originally Posted by doppelganger View Post
    Standard fit has the brightness controlled from the MMI, not sure if that would be replicated by a retrofit.
    Now: 2016 C7 2.0TDi BE with Tech Pack, magic parking, ambient lighting
    Previous: 2013 C7 2.0 TDi S Line
    C6 2.0 TDI LE
    A4 2.0 TDI SE
    and an ancient 80 in the olden days...
  5. Re: A6 Ambient Lighting Retrofit
    #35
    May 2020
    Scotland, Ayrshire
    I have activated the background lighting control in my mmi via vcds (registered version). this was done to control the brightness of the footwell lighting. i was wondering if there was an additional module, or different way of wiring so it was controlled through the mmi and not the dial beside the healight switch
    WhatsApp Image 2020-05-18 at 20.52.12 (1).jpgWhatsApp Image 2020-05-18 at 20.52.12.jpg
  6. Re: A6 Ambient Lighting Retrofit
    #36
    May 2020
    Scotland, Ayrshire
    Quote Originally Posted by nevbadger99 View Post
    please see the message above. i messed up and forgot to quote you!
  7. Re: A6 Ambient Lighting Retrofit
    #37
    Dec 2008
    I'm researching this retrofit and this afternoon tried various adaptations using VCDS (also registered version) but couldn't get that option to appear in the MMI. My A6 Avant Black Edition is a 2018 (facelift) model, why version is yours?
  8. Re: A6 Ambient Lighting Retrofit
    #38
    Dec 2008
  9. Re: A6 Ambient Lighting Retrofit
    #39
    May 2020
    Scotland, Ayrshire
    Quote Originally Posted by SBJ View Post
    I remember having difficulty getting this to work, however try this:
    let me know how you get on buddy
  10. Re: A6 Ambient Lighting Retrofit
    #40
    Dec 2008
    Thats brilliant, I will take a look. Out of interest, how did you wire in the door bar lights? Can only see the guide on here that taps into the interior door handle LED and dimmed via the rotary knob by the headlight switch. Can't find how to wire into the door module to then be controlled by the MMI. Any pointers would be welcomed!
    Once I know that, I'll then order parts.
  1. Ambient lighting retrofit
    By James Hamilton in forum Q7 - 4M Forum - 2016 -
    Last Post: 02-07-2021, 06:03 PM
  2. ambient lighting vs lighting package
    By robbyg in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-09-2015, 04:47 PM
  3. Replies: 8
    Last Post: 10-09-2014, 12:39 AM
  4. Red LED ambient lighting, retrofit?
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-07-2011, 11:21 AM
  5. a4 cab ambient lighting
    By papalion in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2011, 11:34 PM
