Thread: A6 Ambient Lighting Retrofit
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
  1. A6 Ambient Lighting Retrofit
    Jul 2017
    Newcastle Upon Tyne
    Couldn't find a good guide anywhere to retrofit ambient lighting in door cards so thought id make one.
    Parts are all available from dealer and it works out about £110 for the 4 doors.
    This retrofit can be done without vcds, and so no coding is required. Brightness is controlled via knob on light switch panel.
    Parts needed -
    Driver door: 4G0919174A, 4G0947355C, 8W0971832
    Passenger door: 4G0919173A, 4G0947355B, 8W0971832
    Rear right door: 4G0919178A, 4G0947355C, 8W0971832
    Rear left door: 4G0919177A, 4G0947355B, 8W0971832
    For the wiring you will need 2x 000979009E, they come in packs of 5.
    You will also need T25 screwdriver, trim tools, flathead screwdriver, heat shrink tubing, insulating tape, something sharp to cut wires.
    Optional things would be cloth tape to give oem look and stop wires from rattling inside door and would definitely recommend some spare door clips as some tend to break when taking door card off.
    Start by prying off trim and speaker cover to reveal 2 screws, final screw is located under handle.
    Once screws are removed there is a tab you need to press, as shown in the picture, which undoes a clip inside the door. Then use a trim tool to pry door card off. Some clips can be really reluctant to come off, best thing to do is use trim tool to pry door card off enough to get your fingers under and pull. You will need to roll down the window, then push up to slide the door card off.
    Once door card is removed, unplug connector from door module and disconnect wire from door handle. The door card should now come off completely.
    There is a small gap that you slide the end of the light bar through, then push each of the clips into their slots, you should not be able to see the light bar at all when clipped in, if you can you haven't pushed it in enough.
    Now to the wiring: You will need 2 wires for each door. Mark one wire with tape at each end, so you can identify this as your ground wire. Strip one end of each wire and twist the end.
    Plug the other end of each wire into the connector. The ground wire (with the tape on) goes into plug 1 on the connector. Once this is done you can tape up with cloth tape.
    You are going to tap into the wires for the door handle led so remove the connector, then remove wires from connector. To remove the wires the top of the connector slides off, then use the flatheaded screwdriver to release wire from connector. Strip part of the cable to reveal wire, use the screwdriver to part the wires in the middle. One wire will be solid brown, this is the wire you will put your ground wire through.
    Slide your wire through and twist round. Do the same with live wire. Then slide heat shrink tubing over and heat up to seal cable. Put wires back into connector, brown wire goes to plug 1 on connector. then connect back up to door handle led.
    Now plug the other end of your wiring to the led and then attach your led to the light bar. There is a small clip on led that goes into a slot and secures it to the door card.
    Connect everything back up, take care to make sure wire for door handle is put back properly.
    Each door will take about 30mins, takes very little effort, I am a complete novice at wiring and found this pretty easy.
    I will be doing ambient lights in centre console soon so will do a guide for that too.
    1 6 0
  2. Re: A6 Ambient Lighting Retrofit
    Aug 2009
    Near Lanark
    21 Post(s)
    I wondered what ambient lighting was.....but I know I've got 2 small LEDs in my interior light and I have the red light bars in my door handles....so I'm guess that's it.
    I didn't realise the variable brightness control also controlled the ambient lighting.....I wondered.....Is it possible to brighten the small light bars in the door handles a bit without the dash becoming too bright and distracting? Can they be independently controlled?
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  3. Re: A6 Ambient Lighting Retrofit
    Jul 2017
    Newcastle Upon Tyne
    Ambient lighting includes the light bars in door cards and pockets along with the centre console. If you have it from factory you control it in the mmi.
    Because you tap into wires for door handle lights for this retrofit it makes it possible to dim them like you'd dim the other interior lights. Whether you can brighten the door handle lights.. I'm not sure, maybe with vcds?
  4. Re: A6 Ambient Lighting Retrofit
    Mar 2014
    Edinburgh
    230 Post(s)
    That's a good effort.
    Are you planning to fit the illuminated sill/kickplates? Would love to see how they are wired up. I have the lighting pack and the only thing missing is the illuminated kick plate from the ambient pack.
  5. Re: A6 Ambient Lighting Retrofit
    Aug 2009
    Near Lanark
    21 Post(s)
    Quote Originally Posted by a6duke View Post
    Yeah....fitted from factory.
    I'll search through mmi and I also have vcds so I'll see what I can find out regarding that...cheers
    Sent from my SM-G920F using Tapatalk
  6. Re: A6 Ambient Lighting Retrofit
    Jan 2018
    London
    Hi! Did you fit ambient lights in the central console?
  7. Re: A6 Ambient Lighting Retrofit
    Jan 2019
    Glasgow
    Where do you recommend buying the parts from? I canít seem to find them available anywhere?
  8. Re: A6 Ambient Lighting Retrofit
    Jun 2015
    Ireland
    51 Post(s)
    I just priced the parts with my local dealer. Itís 114euro. I think ill give it a shot! I may as well fit rear door warning lights once i have the side boards out.
    2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  9. Re: A6 Ambient Lighting Retrofit
    Jun 2015
    Ireland
    51 Post(s)
    I got all the parts and attempted the installation. I have completed the front doors and will do rear doors tomorrow. I started from the passenger front as a sandbox and unfortunately broke one of the plastic strips. Iíll check later on if you can notice that during the night.
    Ps: by reversing the wires you can change the led colour to red. I connected them to light red. I think it will match interior colours better. Iíll take pictures and post them here later on.
    0 3 0
  10. Re: A6 Ambient Lighting Retrofit
    Jun 2015
    Ireland
    51 Post(s)
    Here is the driver door
    0 3 0
  1. Ambient lighting retrofit
    By James Hamilton in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-02-2018, 11:01 PM
  2. ambient lighting vs lighting package
    By robbyg in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-09-2015, 04:47 PM
  3. Replies: 8
    Last Post: 10-09-2014, 12:39 AM
  4. Red LED ambient lighting, retrofit?
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-07-2011, 11:21 AM
  5. a4 cab ambient lighting
    By papalion in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2011, 11:34 PM
free web
stats
