Thread: Water in boot lid destroying rear lights
Results 11 to 20 of 28
  1. Re: Water in boot lid destroying rear lights
    Aug 2017
    Bathgate
    14 Post(s)
    Quote Originally Posted by Lukenkarl View Post
    If it is similar to the C6 boot, there are two plugs at the bottom of the boot either side. Take em out and bin them. Water sometimes gets in through the boot handle when you have the boot open when it rains. Like if your using it as a shelter.
    Thanks mate, I took all four plugs out and that helped drain the water out.
    I think it's getting through the left inner light. No idea how yet.
  2. Re: Water in boot lid destroying rear lights
    Feb 2016
    Hungary
    113 Post(s)
    Quote Originally Posted by hotgogs View Post
    I still suggest to check the sealing there.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  3. Re: Water in boot lid destroying rear lights
    Aug 2017
    Bathgate
    14 Post(s)
    Quote Originally Posted by AT. View Post
    There is no seal between the light and body. Is the supposed to be?
  4. Re: Water in boot lid destroying rear lights
    Feb 2016
    Hungary
    113 Post(s)
    It was a hard to find, took a long time, but I found my post with my pictures. So, here they are, please refer to my issue:
    Are the rear Tails lights a sealed unit ?
    As you can see, this kind of a sealing solution is not very practical, as you can't see damage from the outside, while the sealing could be absolutely useless in the inside.
    Im my case, it seems that sometimes, somewhere, somehow something hit the lamp unit, and that caused the problem later.
    To be honest, it seems to me, that this is a one time sealing solution, so IMHO if you remove the unit, you will have to replace this "duck tape" like solution, even it was good before the removal.
    1 1 0
  5. Re: Water in boot lid destroying rear lights
    Mar 2014
    Edinburgh
    235 Post(s)
    I think there are 2 type of rear lights. Led and halogen types. The halogen ones are meant to be removed as bulbs are serviceable by the owner where as the led ones are sealed for life.
  6. Re: Water in boot lid destroying rear lights
    Feb 2016
    Hungary
    113 Post(s)
    Quote Originally Posted by A6S View Post
    In my case - with this kind of sealing - I have LED+halogen, all LED, except the rear white light, which is halogen in my case.
    However you can be right about the two types, because if I remember well, I read somewhere that the new units are full LED, including the white light too.
  7. Re: Water in boot lid destroying rear lights
    #17
    Mar 2014
    Edinburgh
    235 Post(s)
    I think my old s line had a halogen/filament bulb for reverse and rest was led.
    There's was a credit card type tool that came with the halogen Ones to remove the whole light cluster for changing bulbs if I remember right. Halogen was se spec for U.K.
  8. Water in boot lid destroying rear lights
    #18
    Aug 2017
    Bathgate
    14 Post(s)
    Thanks mate. Is the spongey like stuff is supposed to be a seal. My left one looks pretty poor so that makes sense.
  9. Re: Water in boot lid destroying rear lights
    #19
    Aug 2017
    Bathgate
    14 Post(s)
    Just to clear this up for anyone who is following.
    I replaced the cluster and it seems all good now
    The seal above had failed causing water to collect in the boot lid and short the light.
    0 2 0
  10. Re: Water in boot lid destroying rear lights
    #20
    Mar 2014
    Edinburgh
    235 Post(s)
    Can the seal not get replaced or some body sealant be used instead?
    Seems expensive to replace the cluster when a bit of rubber has failed
  1. boot and rear fog and numberplate lights not working
    By foden2012 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-11-2017, 06:38 PM
  2. Replies: 2
    Last Post: 22-01-2012, 08:39 PM
  3. Octavia estate -water at rear lights area
    By david muir in forum Octavia
    Last Post: 29-07-2008, 06:30 PM
  4. Water in Boot and Rear Fog(s)
    By chrisvrscrx in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-03-2008, 06:26 PM
