Thread: Audi transmission/power_train specialist at or near Reading needed
  1. Audi transmission/power_train specialist at or near Reading needed
    Jun 2016
    Reading, UK
    Hi all,
    I would like to ask your advise for Audi transmission specialist located in or near Reading. I have a squeaking noise coming from rear center of the car but unable to pinpoint it.
    Idealy that person would have his own repair shop as well in order to carry on from diagnostics till fixation and testing.
    Thanks in advance,
    Guray
  2. Re: Audi transmission/power_train specialist at or near Reading needed
    Oct 2012
    United Kingdom
    12 Post(s)
    Are you thinking that the prop-shaft bearing has gone?
  3. Re: Audi transmission/power_train specialist at or near Reading needed
    Jun 2016
    Reading, UK
    Yes, indeed, this is my point now. I was advised by my ex-mechanic to find a person capable to pinpoint the point of failure, instead of running expensive replacements. Looking to the current symptoms and information I gathered from internet, this is my current point to believe that rear drive shaft support bearing has gone.
    Regards:
    Symptom: A high pitch whining coming from the center underside of the car. The high pitch noise varies with vehicle speed. Lower pitched at slow speeds and higher pitched at fast speeds. It may even begin to make a screeching noise; especially when driven in cold conditions.
    Repair Solution:
    To determine the cause of the noise put the vehicle up on a repair shop post lift with all four wheels off the ground. Driving the vehicle on lift and using a stethoscope, confirm that the noise is coming from the Audi center support bearing area (see image below). If it is, replace the Audi center support bearing.
  4. Re: Audi transmission/power_train specialist at or near Reading needed
    Apr 2017
    wirral
    i had this with my previous q7 and i bought new centre bearing but as i started to fit it i decided to grease old one it as all looked very dry ,bit of grease job done ,never heard it again.
  5. Re: Audi transmission/power_train specialist at or near Reading needed
    Jun 2016
    Reading, UK
    Thanks, nearly missed it. Another option to consider.
  6. Re: Audi transmission/power_train specialist at or near Reading needed
    Apr 2017
    wirral
    no problem ,mine was a very high pitched squeal,and from memory ithink it happened when i got up to speed ,it really was a very easy fix,good luck.
  1. Audi Specialist in Reading / Maidenhead?
    By mark_88_turbo in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 30-01-2018, 05:44 AM
  2. Audi Q7 specialist needed at Reading (or close)
    By Guray in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-12-2016, 10:39 PM
  3. Audi Specialist Near Reading
    By wapwray in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-09-2010, 09:03 AM
  4. Richard Holder - Independent VW/Audi Specialist in Reading
    By jamoca in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 31-03-2009, 10:26 PM
  5. AUDI / VW specialist needed
    By brickit in forum Archive posts
    Last Post: 20-07-2007, 09:43 PM
