Thread: Code diagnosis please for Audi a4 cab
  1. Code diagnosis please for Audi a4 cab
    Jul 2017
    southport
    3 Faults Found:
    16518 - Oxygen (Lambda) Sensor B1 S1
    P0134 - 004 - No Activity - Intermittent
    17537 - Fuel Trim; Bank 2 (Mult)
    P1129 - 002 - System too Rich - Intermittent - MIL ON
    17535 - Fuel Trim; Bank 1 (Mult)
    P1127 - 002 - System too Rich - Intermittent - MIL ON
    Do I just change the O2 sensor ?
    Regards James
  2. Re: Code diagnosis please for Audi a4 cab
    108 Post(s)
    1816 Post(s)
    It could have a faulty lambda sensor before the cat on bank 1 but that would not make the ECU enrich bank 2 so to me that says stuck open tank vent valve. Try clamping this off from the manifold and run through the basic settings 028 onwards (NOT 060 with the engine running!)
  3. Re: Code diagnosis please for Audi a4 cab
    Jul 2017
    southport
    Great thanks @Crasher, ok , I can try this, but I don't have a vcds tool to run through this, can I do this kind of check without the tool ? I only have a cheap vag com ebay special and a blue tooth odbc socket ?
    Sorry to be a pain, you must get loads of numpties like me fishing for information, but don't have the knowledge or tools to fix them ? (I was kind of hoping it would be th o2 sensor, then I could then just wip is out and replace)
  4. Re: Code diagnosis please for Audi a4 cab
    108 Post(s)
    1816 Post(s)
    Without full VCDS or similar (VAG PRO) you are going to struggle, you need to be able to see the measuring blocks and what happens when you change things. I think the lambda sensor no activity is because the sensor is flooded BUT it still could be faulty. PM me the cars reg number.
  5. Re: Code diagnosis please for Audi a4 cab
    Jul 2017
    southport
    ok, crasher, hoping this might shed some further light on the fault, or worse I've got a completely different unrelated issue.
    So car wouldn't start, this morning, suspect battery, jump started the car, but noticed when I checked the battery at halfords.
    I've getting smoke coming from the engine, and a smell of eggs in the cabin. I initially thought that the air filter might need changing and perhaps clean the aircon, but now with the smoke, I'm thinking that perhaps the car is dumping petrol into the cat and that is what the smell is?
    any thoughts ?
    James
  6. Re: Code diagnosis please for Audi a4 cab
    108 Post(s)
    1816 Post(s)
    When a petrol engine with a cat has been running badly, if the cat fires up again it will stink of sulphur that has accumulated and any oil on the outside of the cat will get very hot and smoke. It could be that the flat battery has zeroed the adaptations in the ECU and it will have to adapt again but you need some diagnostic work doing otherwise it's all guesswork.
  1. Please Help Fresh Audi diagnosis. Help a noob.
    By Mendes Paul in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2015, 10:30 AM
  2. Replies: 0
    Last Post: 03-12-2013, 11:51 PM
  3. Replies: 4
    Last Post: 29-09-2011, 12:36 PM
  4. Audi A6 Fault Diagnosis Help...
    By biker_billy in forum VCDS - Help Requests
    Last Post: 30-09-2009, 06:33 PM
  5. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
