Thread: Reversing mirrors
  1. Reversing mirrors
    Nov 2014
    Aberdeenshire
    I have a 2015 R Line Touareg with standard seats. Reading the handbook it should have mirrors that dip when reverse is selected. But how do I get them to work?
    Sent from my SM-G900F using Tapatalk
  2. Re: Reversing mirrors
    mostly in the garage
    The memory function for mirror dip is part of either of the 2 options available for seat memory.... which you won't have if you have non electric standard seats.
  3. Re: Reversing mirrors
    Nov 2014
    Aberdeenshire
    Oh well. Thanks for the info. Had it on my A6 and it was great.
  4. Re: Reversing mirrors
    Mar 2013
    Reading
    13 Post(s)
    Quote Originally Posted by asr View Post
    No need to give up yet. If it's the same as with Audi, you just need to enable it with VCDS, OBD11 or similar...
    Sent from my mobile...
  5. Re: Reversing mirrors
    Quote Originally Posted by Johnny31 View Post
    Yes but you still can't memorise the position you want it to dip to if you don't have a memory pack.
    Sent from my SM-G935F using Tapatalk
  6. Re: Reversing mirrors
    Mar 2013
    Reading
    13 Post(s)
    Quote Originally Posted by c4a5er View Post
    Worth giving it a go. My A6 for example had mirror dip from factory but w/o memory seat option. You will also see that across the Audi range people generally not complain of problems once it is set (easy to validate in the Audi section here).
    It seems that the module itself can "memorise" the previous position so it will happily flip between the two (revers and fwd) going exactly back to where it was.
    So, it does not hurt to try as I cannot imagine VAG doing such things wildly differently across brands.
  7. Re: Reversing mirrors
    Correct it wouldn’t hurt, done it on many vag cars and it will dip but as said that’s all it does. It just drops, no way to set the amount, no left/right movement either. But if that simple drop happens to miraculously suit your preferred position then fine. Also in my experience the mirrors return position soon goes off and requires tweaking after reversing a few times.
  1. Question Heated Wing Mirrors / Door Mirrors / Side Mirrors / Side Mounted Rear Viewing Devices
    By simonrk57 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-05-2017, 07:53 PM
  2. reversing sensors
    By falcoron in forum Alhambra
    Last Post: 27-05-2015, 07:03 PM
  3. Wing mirrors turn down on reversing
    By Perrina in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-05-2013, 05:37 PM
  4. Question Reversing Camera
    By A4 Lad in forum In Car Entertainment
    Last Post: 15-01-2012, 10:28 PM
  5. Reversing Sensors
    By PirateDave in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-07-2011, 06:50 PM
