Thread: Problem Starting Polo
  1. Problem Starting Polo
    Aug 2006
    Hello All,
    Just wondering if anybody could shed some light on my Polo starting problem. I have a Y 2001 polo 1.4 match and i have started having a problem when starting it in morning, after finishing work, any time really when the car has been left to sit for a while. When i first turn the key to start it, it makes a strange sound.(it doesnt start) then it starts straight away second time turning the ignition key. It has been raining alot recently where i live and i was wondering if it could anything to do will water getting in somewhere in the engine???
    Any advice would be a great help.
    Regards
    ROy.
    Aug 2006
    Berks,Hamps, Surrey corner
    The strange noise might be a lazy fuel pump but a common cause of non starting under your conditions is the coolant temperature sensor. Needle in haystack comes to mind, how about having it code read?
  3. Re: Problem Starting Polo
    May 2007
    Roymarsden,
    Did you manage to resovle the issue with your Polo? Mine appears to be doing the same thing. I was wondering whether you'd be able to point me in the direction of a resolution.
    Thanks,
    Nick
  4. Re: Problem Starting Polo
    1837 Post(s)
    Is it a loud clangy (?!?!) grinding noise?
  5. Re: Problem Starting Polo
    does the strange noise sound similar to when you have a flat battery? the ignition switch on mk4 polos are prone to failing and give a similar symptom to having a flat battery. turn the key a few times and it will normally fire after 5 or 6 goes. does your car have an immobiliser also? more info needed really
  6. Re: Problem Starting Polo
    Mar 2008
    Hello,
    Did you ever solve the problem? Only I got in my 1995 1.3 polo tonight, which for a couple of weeks has been starting on the 2nd turn (1st turn no sound, nothing). I started the car fine, then turned the lights on and everything instantly cut out. There's no power at all now, not even the central locking works. I'm wondering if it's a fuse that's blew or maybe the ignition as the battery reads 100%
  7. Re: Problem Starting Polo
    1837 Post(s)
    Could be the ignition switch, a common failure on the Polo 6N.
  1. Polo intermittently not starting
    By Gee Bee in forum Polo - Derby - Lupo - Fox
    Last Post: 24-01-2007, 09:44 PM
  2. TDI starting problem
    By j_coupland in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-08-2006, 11:46 AM
  3. Cold starting probs on Polo Diesel
    By billyboy in forum Polo - Derby - Lupo - Fox
    Last Post: 29-08-2006, 10:34 AM
  4. vw polo, starting and flutter problems
    By zak321uk in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2006, 01:50 PM
  5. starting problem
    By andrew006 in forum 80 - 90
    Last Post: 10-02-2005, 06:44 PM
