Thread: Air Con High Pressure Sensor
  1. Air Con High Pressure Sensor
    Port Talbot, South Wales
    44 Post(s)
    I posted a few weeks ago about how I’d had an air con service and the air con wasn’t blowing cold afterwards.
    Been back to the dealer today and they say they need to do some wiring checks but they think a sensor is gone on the ‘high pressure side’ of the system. The part is £66 and fitting is £120.
    I asked why this hadn’t been picked up during the service and they said they only change the gas and oil in an air con service which seems fair enough.
    £120 to change a sensor while I wait seems a bit heavy as well as £66 for a part. Anyone got any suggestions/comments or has experience this?
  2. Re: Air Con High Pressure Sensor
    Jul 2015
    Staffs
    46 Post(s)
    Guess it depends how accessible the sensor is. If it's the pressure sensor sometimes the bumper needs to come off etc. Maybe get some other quotes if you're concerned about the price?
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Air Con High Pressure Sensor
    44 Post(s)
    Quote Originally Posted by rowdy-999 View Post
    Can’t imagine they’ll be removing the bumper on a while u wait appointment can you?
  4. Re: Air Con High Pressure Sensor
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    If its on high pressure side wont they need to recover the gas, change sensor then recharge the gas? That could be what the labour charge is for.
  5. Re: Air Con High Pressure Sensor
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by JonathanK View Post
    Just shy of £200 and they ‘think’ it’s the sensor! They gonna refund you if it isn’t?
    No experience on the A6 but in my old car it was behind the bumper.
  6. Re: Air Con High Pressure Sensor
    Mar 2016
    Minervois, France
    53 Post(s)
    My AC high pressure sensor is behind the front bumper, just below the RH headlight. But it only takes a few minutes to remove the bumper - one small screw in the liner in each wheel arch and two mounting bolts, accessed through the pop-out vents towards the outsides of the bumper, or behind the fog lights, if fitted. There are Youtube videos showing how to disconnect the bumper from the wheel arches.
    I don't know about your AC sensors, but mine have Schrader valves in the ports they screw into - the sensor tip opens the valve as it is screwed in - so that they can be removed and replaced without losing the refrigerant (what you call "gas").
    When removing a sensor, after slackening it, it should be screwed out rapidly so the valve closes as quickly as possible, to minimise any loss of refrigerant.
    I would get another quotation for that job, preferably from a qualified car aircon specialist.
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
  7. Re: Air Con High Pressure Sensor
    Mar 2018
    GB
    19 Post(s)
    www.airconditiongforcars.co.uk, a clued up bloke who posts some generic fixes on his page, if they've over filled the system that could cause the same issue. And if I was cynical I'd say they were blagging you off with unnecessary work.
    Sent from my SM-G900F using Tapatalk
  1. Question Air Con High Pressure Sensor (G65) Location
    By dragondownsouth in forum A8 - S8 - V8
    Last Post: 30-06-2015, 06:52 PM
  2. A/c High-Pressure Sensor( G65) Part no
    By arvyidas in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-06-2013, 05:03 PM
  3. Replace High-Pressure Sensor/Thrust sensor G65)
    By jrabkid in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2013, 04:15 PM
  4. a3 high pressure sensor g65 location
    By rhosj in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-09-2012, 12:35 AM
  5. high pressure sensor G65 ??
    By MPJ in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-12-2008, 01:46 PM
