Thread: Golf 1.9 TDI Brake Sizes
Results 1 to 10 of 10
  1. Golf 1.9 TDI Brake Sizes
    Jul 2017
    Somerset, UK
    I'm going to buy some high performance disc and pads for my TDI.
    What's the best way to know the sizes for the discs and the right pads?
    Also what's recommend Brembos, EBC?
    Thanks,
    Jay
    Sent from my ONEPLUS A3003 using Tapatalk
  2. Re: Golf 1.9 TDI Brake Sizes
    May 2012
    Everywhere
    308 Post(s)
    Grooved and drilled don't do much .
    Normal Brembo discs with EBC Redstuff will work well .
    Where possible up a disc size by purchasing a used caliper carrier , my Passat went from 288mm to 312mm , the laws of leverage physics give a real change .
  3. Re: Golf 1.9 TDI Brake Sizes
    Dec 2010
    Worcs, UK
    Look at the PR Codes, they will tell you what you need.
  4. Re: Golf 1.9 TDI Brake Sizes
    Jul 2017
    Somerset, UK
    I can't find my pr code under or by my spare wheel and I don't have the service book
  5. Re: Golf 1.9 TDI Brake Sizes
    1836 Post(s)
    Straight forward 288's. Black Diamond 12 grove and Predator pads work very well. Cross drilled discs are a waste of money.
    we do these in 12 groove http://www.ebay.co.uk/itm/Audi-A3-4W...item19cc298199 but eBay have ruined our (and everyone else's) listings but it points you in the right direction.
  6. Re: Golf 1.9 TDI Brake Sizes
    Jul 2017
    Somerset, UK
    So 288 on the front discs
    What about the rears and the pads too
  7. Re: Golf 1.9 TDI Brake Sizes
    May 2012
    Everywhere
    308 Post(s)
    No brainer , if it's 288mm get some second hand 312mm caliper carriers and 312mm discs , the pad remains the same 288 or 312 .
  8. Re: Golf 1.9 TDI Brake Sizes
    1836 Post(s)
    Yes 312 works very well and even just fits inside a 16. Rears, just bog standard Golf 5, fit Pagid discs and pads and save the money over fancy stuff for when you find you need two new calipers.
  9. Re: Golf 1.9 TDI Brake Sizes
    May 2012
    Everywhere
    308 Post(s)
    New calipers not required as 312mm caliper carriers space out existing 288mm calipers .
  10. Re: Golf 1.9 TDI Brake Sizes
    1836 Post(s)
    Rears....
    Although you raise an interesting point, WHY are the front calipers for a 288 to a 312 OFFICIALLY different but both are interchangeable? Tis one of life's unanswered questions such as, which day do I die......?
  1. Brake disc sizes
    By QuattroSpain in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-03-2012, 06:04 PM
  2. Question Brake discs sizes
    By spako in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-02-2012, 11:16 PM
  3. Default vw golf mk4 genuine brake discs sizes?
    By ALIN in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2010, 11:07 PM
  4. Brake disc sizes
    By Boumsong in forum Scirocco - Corrado
    Last Post: 15-06-2008, 08:37 PM
  5. Question Help! Brake disc sizes on mk4 golf gt tdi 130
    By Hotrocks888 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-05-2008, 02:01 PM
