Thread: What's leaking oil? Front right corner high up
  1. What's leaking oil? Front right corner high up
    May 2008
    26 Post(s)
    I know the pics are bad and somehow every pic I'm posting lately is getting resized to tiny, but can anyone see what might be leaking what seems to be oil in the front right corner, fairly high up in the engine? I do have a vcds fault code for N145 engine solenoid valve, but have been told this is harmless.
    I'm not 100% sure it's oil. It's definately black and wet but it could be hydraulic fluid or coolant mixed with engine gunk.
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  2. Re: What's leaking oil? Front right corner high up
    May 2014
    Darlington
    78 Post(s)
    Is this the 3.0TDi Engine?
  3. Re: What's leaking oil? Front right corner high up
    May 2008
    26 Post(s)
    No it's a 3.2 FSI
  4. Re: What's leaking oil? Front right corner high up
    May 2008
    26 Post(s)
    Managed to get another pic looking upwards and from the side. The shiny thing is leaking. It's at the top of the engine, on the right hand side (looking from inside the car) and on the front of the engine, right behind the fan. What is this please?
  5. Re: What's leaking oil? Front right corner high up
    May 2008
    26 Post(s)
    Looking in ssp325 it seems like a cover plate over the camshaft adjusters. Guess it must be oil leaking then due to bad gasket? How serious and is it likely to deteriorate do you think?
    http://www.volkspage.net/technik/ssp/ssp/SSP_325.pdf
  6. Re: What's leaking oil? Front right corner high up
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    I personaly have this problem on my 2.7tdi for 3 years now. No problem 'till today. There is no gasket on that side, it's only sealing paste. here:
    If you want I can take a look at your engine type but I need all the data about your car.
  7. Re: What's leaking oil? Front right corner high up
    May 2008
    26 Post(s)
    Thanks L3, maybe it's a common issue which doesn't lead to a failure? Thank you for your offer of help. I have elsawin too so will look for that diagram for my engine.
  1. Water leaking through front door trims
    By Hawthorn37 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-05-2016, 11:16 PM
  2. Please Help 98 a4 convertable leaking fuel from in front of rear wheel
    By galva in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-08-2012, 11:36 AM
  3. allroad suspension high at front
    By herald in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-12-2010, 08:47 AM
  4. Please Help touran passanger side front and rear wet leak leaking
    By drunlock in forum Touran - Sharan - Caravelle
    Last Post: 18-01-2009, 10:36 PM
  5. Front Suspension Leg Leaking
    By stevek in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2007, 05:54 PM
