Thread: What is the cause of Noise from engine?
Results 1 to 8 of 8
  1. What is the cause of Noise from engine?
    Dec 2015
    Harlow, England
    My 2006 Passat 2.0dti 140S has developed a rattling noise in the engine. It's early stages but I stopped and parked it immediately. What is the course? Any ideas please.
    It only has 95000 on the clock.
  2. Re: What is the cause of Noise from engine?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    A well known fault with those engines at that sort of mileage is the oil pump drive failing, your rattling could be a symptom of low oil pressure, dual mass flywheel is another rattler, does the noise change when you dip the clutch? hopefully though it's something simple like a loose exhaust, auxy belt tensioner or plastic cover, hard to say without seeing and hearing it.
  3. Re: What is the cause of Noise from engine?
    Dec 2015
    Harlow, England
    I thought I might give feedback on the engine noise question I posed about my 2.0 dti Auto 2006 with 97k mileage after I took it to VW in town. They surprised me by saying the noise was the first symptom of the impending clutch failure that I should expect in 6 months time. I told them this was an Auto box car; they answered yes but it has a manual gearbox with a clutch that is operated by sum clever electronics.
    I was relieved even though I still have to fix the clutch.
  4. Re: What is the cause of Noise from engine?
    1840 Post(s)
    Yes the DSG still uses a DMF but you can get these aftermarket from LUK for much less than a VW dealer and have it fitted by an independent. The clutch pack is completely separate to the flywheel, being inside the box, so you do not need to do the clutch, in my experience these last around 200k miles. With it being a 2006 I would strongly recommend that the sump was removed and the condition of the oil pump chain drive system checked, if it is worn, system should be converted to spur gear drive.
  5. Re: What is the cause of Noise from engine?
    Dec 2015
    Harlow, England
    Thanks Crasher, I am taking your advice seriously. I would not like to lose this engine through silly mistakes when I have been for-warned. So my priority is to remove the sump and check what is going on with the oil pump. But I have now encountered a stumbling block with the sump bolts. The 2 between the engine and gearbox are located inside some long narrow holes and have an awkward angle which prevent a prower grip with both the No. 10 and the allen key. Does anyone know how I can get them to turn without rounding the ages? I am now desperately looking for a mobile mechanic. I have spent money on new tools in vain. I also want to change the hexa-pin drive as well as the cam-belt and water pump.
  6. Re: What is the cause of Noise from engine?
    May 2012
    Everywhere
    308 Post(s)
    Engine code ?
  7. Re: What is the cause of Noise from engine?
    Sep 2008
    chester
    17 Post(s)
    you need a long hex allen key with a ball end but depends whether you can get them out with the flywheel in situ.
  8. Re: What is the cause of Noise from engine?
    1840 Post(s)
    I use a long ball ended 5-mm hex key or a 1/4 " drive wobbly end extension with short 10-mm socket depending on the bolt design.
  1. V5 20v engine noise on chain side of engine
    By craig-v5-20v in forum Toledo
    Last Post: 09-01-2015, 11:33 AM
  2. Question Golf tdi ALH engine... Engine knocking noise. Help wanted
    By Onionss74 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2014, 08:29 PM
  3. Question Audi A4 3.0 Conv 2004 - Engine whining noise from front of engine.
    By alancobra in forum New Member Introductions
    Last Post: 09-01-2013, 06:10 PM
  4. Engine/Transmission - Vibration/Noise at certain engine revs
    By audikid in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-08-2012, 09:32 AM
  5. engine noise - pulleys or bearing noise
    By johnmccracken in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-08-2011, 02:28 PM
