Thread: Please help! Engine fault garage glow plug light flashing
Results 1 to 9 of 9
  1. Please help! Engine fault garage glow plug light flashing
    Jul 2017
    Hi I've got a 2005 golf gt tdi 140 bkd and it keeps juddering, only once in a while but when it happens it's bad, it only seems to happen when the engine is hot! And when it happens my glow plug light flashes and comes up with engine fault garage but I'll turn my ignition off and it will dissapere till next time had it plugged in and only one fault code for egr but that's because I've blanked it off, also it has been cutting out randomly.
  2. Re: Please help! Engine fault garage glow plug light flashing
    Jul 2017
    Callum this sounds like a very big issue with your golf. I'd take it to a trained mechanic if I were you. It'll probably be a lot of work on your own.
    Mr Dawg is my Father's name
  3. Re: Please help! Engine fault garage glow plug light flashing
    108 Post(s)
    1816 Post(s)
    Check the fuel filter to make sure it isn't black and full of engine oil.
  4. Re: Please help! Engine fault garage glow plug light flashing
    Jul 2017
    Thanks I'll check that when I get home from work, it's strange because it only happens when the engine is at operating temperature
  5. Re: Please help! Engine fault garage glow plug light flashing
    Jul 2017
    Hi mate I've checked my fuel filter and all seems fine took abit out and left in a cup to settle and all looks good
  6. Re: Please help! Engine fault garage glow plug light flashing
    108 Post(s)
    1816 Post(s)
    It could be that the ECU is getting upset about you blanking off the EGR system, it's illegal anyway. If that is the only fault code coming up, re-instate the EGR and try it.
  7. Re: Please help! Engine fault garage glow plug light flashing
    Jul 2017
    I've took it to the garage and they don't know what's up with it, I've bought myself a little code reader and Un blanked the egr and no fault codes have come back, but the judder is getting worse
  8. Re: Please help! Engine fault garage glow plug light flashing
    108 Post(s)
    1816 Post(s)
    The trouble is with that code reader you may only be seeing OBDII codes, not all of the codes the ECU can show are OBDII, don't you know of a decent VW specilsist near you?
  9. Re: Please help! Engine fault garage glow plug light flashing
    Jul 2017
    I'll get it to a garage tonight, I'll keep you all posted, thanks
  1. Please Help Engine Fault GARAGE - Glow plug light starts flashing
    By scottjenkins in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-08-2015, 10:25 PM
  2. Please Help passat b6 DPF FAULT LIGHT AND glow plug FLASHING.
    By usa in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2015, 02:39 AM
  3. Please Help On start up intermittent glow plug flashing non start engine fault garage flashes up
    By dazcheff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 08:39 PM
  4. DPF, Flashing Glow Plug and Engine Mang Light on..
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-08-2011, 01:06 PM
  5. Engine cut out and flashing glow plug light Help!
    By jetbox in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-03-2011, 08:08 PM
