When i close the door, only light blinkin. How to i get the sound comin too?
I want to know How To - Activate / Deactivate Locking Confirmation Via Horn. Using VCDS & Ross-Tech HEX-V2 cable.
Code:
Thursday,20,July,2017,10:23:06:03855
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: VSSZZZ6JZGR060551   License Plate:
Chassis Type: 6J (6C0)
Scan: 01 03 08 09 10 14 15 17 19 44 55 5F A9
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-DAJA)       Labels: 06K-907-425-V1.clb
   Part No SW: 6C0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0B1900322424010B0000
   Shop #: WSC 00049 770 00111
   ASAM Dataset: EV_ECM18TFS0206C0906264 001004
   ROD: EV_ECM18TFS0206C0906264.rod
   VCID: 6492A52D4EDB4FD7A91-8030
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08503521151022
   Coding: 12DD687D8B2933C00919306E00524816D1CC900C0012CF098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 37282261AFCD744FDC3-8062
Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
   Part No SW: 6P0 907 044 B    HW: 6P0 907 044 B
   Component: Climatronic   H01 0202
   Serial number:  1510293A-0107
   Coding: 000000001001000001
   Shop #: WSC 00049 770 00142
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_SK25.rod
   VCID: 303A197D4AA3A3779D9-8064
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0086
   Serial number: 001588177949
   Coding: 08000A5042132AFB4B044000402F07580001690253010000000000000000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005_VW26.rod
   Rain Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y15M11D06H04M36S50
   Coding: 00984D
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 801 DT    HW: 6R0 959 801 DT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0630
   Serial number: KU0KU020101552935266
   Coding: 1400A5
   Front Passengers Door Control Module:
   Subsystem 3 - Part No SW: 6R0 959 802 EE    HW: 6R0 959 802 EE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0630
   Serial number: KU0KU022101552952026
   Coding: 0400A5
   Relative Air Humidity Interior Sender:
1 Fault Found:
922631 - Indicator Lamp for Driving Profile Selection
          B1428 11 [008] - Short to Ground
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 55
                    Reset counter: 143
                    Mileage: 21850 km
                    Date: 2017.07.17
                    Time: 10:59:52
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 K    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0054
   Revision: --------    Serial number: 39391530000150
   Coding: 0031051001
   ASAM Dataset: EV_EPHVA18AU3700000 002026
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 43D046B1EB1528EF70B-8016
Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
   Part No SW: 6C0 907 359     HW: 6C0 907 359
   Component: DAEMPFUNGS-SG H04 0007
   Serial number: 17101502000112
   Coding: 80
   ASAM Dataset: EV_SwitcDampeContiTemic 001004
   ROD: EV_SwitcDampeContiTemic.rod
   VCID: 6A8ECB15ACFF19A793D-803E
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 G    HW: 6C0 959 655 G
   Component: VW20Airbag01J 001 0360
   Revision: --------    Serial number: 003RK0004PLE
   Coding: 88C0C000008000005C0000CA000800000000
   ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 410 271 610 15
   Component: SideSensor_Df  15B 0148
   Serial number: 3495R00C31CFCD3501C8
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 410 271 610 15
   Component: SideSensor_Pf  15B 0148
   Serial number: 3505R00991CF7C14018X
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels: None
   Part No SW: 6P0 920 746 A    HW: 6P0 920 746 A
   Component: KOMBI         208 1423
   Coding: 072D01003980000800082A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 33301671BBB5986FE0B-8066
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0086
   Revision: --------    Serial number: 001588177949
   Coding: 030100046F00590071000028880000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 6594B82945E136DFBEF-8030
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B1426071015
   Coding: 002000
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 62237L32034351545720
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CFB50038
   Coding: 800700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW_SE26.rod
   VCID: 6D84C0099D110E9FF6F-8038
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 05CA010003000000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 40DA49BDFA0333F76D9-8014
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 290000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 290000
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5QA 035 824     HW: 5QA 035 824
   Component: MU-S--ER      H24 0245
   Serial number: SEZAZ2R0505252
   Coding: 04520400960A000011110001000808002F0302C40120010002
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE26.rod
   VCID: 7DA4F049CD719E1F46F-8028
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5F0 919 604     HW: 5F0 919 604
   Component: ABTm_Std2  H43 1028
   Serial number: SEZ8Z9RFS00RSS
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 6P0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 150520200203
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 75B4E869F541C65F0EF-8020
End----------(Elapsed Time: 00:48, VBatt start/end: 13.0V/13.0V)-----------
