Thread: Flashing battery light and clunky noise on medium/hard acceleration
  1. Flashing battery light and clunky noise on medium/hard acceleration
    Mar 2012
    ashton-under-lyne uk
    The battery light will flash 3 times when i accelerate medium to hard and then the engine will judder slightly. Runs smooth when i drive like a grandad. Other symptom is a clunky squeaky noise on start up and when setting off at low revs.
    I have a few theories that the belt is slipping or one or more pulleys are fudged. My aircon doesnt work so it could be the pump is starting to seize, or it could be the bloody alternator clutch pulley thats had it.
    Anyone experience similar issues and can shed light? Im planning to change the aux belt and tensioner anyway, also sourced a decent 2nd hand alternator too.
    Thanks in advance
  2. Re: Flashing battery light and clunky noise on medium/hard acceleration
    Jul 2007
    somerset
    8 Post(s)
    Sounds like the one way clutch pulley on your alternator has given up.
  3. Re: Flashing battery light and clunky noise on medium/hard acceleration
    Mar 2012
    Ive seen a method to test the pulley on youtube so ill be checking later. Thought it might be that.
  4. Re: Flashing battery light and clunky noise on medium/hard acceleration
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    You don't say if it's petrol or diesel, if diesel you can just remove the aircon belt if you have no intention of repairing the system. Not sure about a petrol.
    I've had to replace a few clutch pulleys on alternators, you need the special tool though.
  5. Re: Flashing battery light and clunky noise on medium/hard acceleration
    Mar 2012
    Sorry rob, i have the petrol 1.8t bex. The aircon hasnt worked since i got the car over 2 years ago. Finally seen a decent replacement on ebay so ill be doing that too. Ive spoken to a garage near me and they can remove my damaged pulley if needed but i need to take my alternator to them, no hard job as its been off a few times.
    Trying to get a hold of a genuine pulley from tps, dont fancy a cheap one just for it to go again.
  6. Re: Flashing battery light and clunky noise on medium/hard acceleration
    Mar 2012
    Managed to get dirty today. The alt clutch pulley is seized. Doesnt rotate either way when stopping the blades/arms inside the alternator with a screwdriver.
    Plus ive figured out why the aircon doesnt work...the pump pulley looks like a bombs gone off inside. Theres an opening on the side of the pulley and you can see inside slightly. All i can see and hear is fragments of metal and rumbling. Think ill be putting orders in for a recon alternator and aircon pump.
  1. Replies: 0
    Last Post: 23-08-2015, 06:34 PM
  2. battery light keeps flashing
    By sar02 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-01-2013, 01:48 PM
  3. Question Battery Light Flashing
    By Screedman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-05-2012, 09:17 PM
  4. Replies: 0
    Last Post: 18-01-2012, 02:52 PM
  5. Please Help Random flashing battery light
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-07-2011, 06:22 PM
