Thread: New satnav disc.... will it work with hacked SDS ?
  1. New satnav disc.... will it work with hacked SDS ?
    Apr 2014
    England
    Fitted: RNS-E Mk1
    does anyone know that if i have the RNS-E mk1 and it shows SW=X (meaning hacked SDS), that if I buy a new satnav disc say 2016 will it work as normal or will the SDS part cause it too play up? (I am unaware of what software/firmware the satnav is running as it shows SW=X
  2. Re: New satnav disc.... will it work with hacked SDS ?
    Mar 2013
    Cardiff
    Your previous post is a big clue about the root cause of your problem. You could try asking the supplying dealer to "do the upgrade" for you once you establish the cost. Failing that there are trusted aftermarket upgraders who should be able to answer your question and do the work, Hazydayz spring to mind.
    Probably in a pit underneath a steam loco somewhere.
  1. Question Audi Satnav - Hacked SDS
    By b0red0m in forum In Car Entertainment
    Last Post: 18-07-2017, 05:03 PM
  2. 2007 Audi A6 Avant 3.0 Le Mans SatNav disc
    By keni010 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-11-2015, 03:37 PM
  3. Question Disc Satnav update
    By Boy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2015, 07:40 AM
  4. RNS-E not reading satnav disc
    By Monsieur in forum In Car Entertainment
    Last Post: 08-03-2014, 12:45 PM
  5. RNS 510 SatNav - disc supplied?
    By bertj in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 05-08-2012, 07:18 PM
