Thread: Oil change interval PD 130
Results 1 to 10 of 15
  1. Oil change interval PD 130
    Jun 2016
    London UK
    My car has 149k on the clock, it's an AWX 1.9 PD.
    It was on longlife servicing before I got it, so I'm staying with the longlife oil but shortening the service intervals. What is the recommended interval for a car that makes a lot of short trips? I drive 10 miles to work, occasionally do some long motorway runs but mostly it's just pottering around locally.
    10k miles seems a bit extreme for this kind of service, would 5k be sufficient using longlife oil or should I go shorter?
  2. Re: Oil change interval PD 130
    43 Post(s)
    10k/1yr is sufficient.
  3. Re: Oil change interval PD 130
    Jun 2016
    London UK
    What are you basing this on? I keep hearing about how short trips cause moisture to get into the oil and unless you run the car for a good couple of hours it doesn't boil off, and over time that sludges up the oil.
    Does the longlife oil somehow protect itself against that?
  4. Re: Oil change interval PD 130
    May 2012
    Somerset
    204 Post(s)
    20 or less LongLife oil , 4 Mann oil filter , do it every 6 months !
    LongLife oil will perform better as more dispersants and detergents in the additive package .
  5. Re: Oil change interval PD 130
    Dec 2009
    Waterlooville U.K.
    12 Post(s)
    Lots of short trips with the engine oil not reaching normal temperature can cause increased engine wear. The combustion by-. products are not burnt off and condensation is a problem ( in the exhaust as well). I once knew a guy with an immaculate old very low mileage morris minor. He did not think that the engine oil needed to be changed very regularly due to the very low mileage. The engine sounded like a bucketful of loose spanners !
    I would be very suspicious of long life oil at 20 ( 4L ?). Counterfeit oil is not uknown.
    Skoda Octavia II SE 1.9PD TDI
  6. Re: Oil change interval PD 130
    May 2012
    Somerset
    204 Post(s)
    20 and 5L .
    Lol , it's VW's own oil made by Fuchs !
  7. Re: Oil change interval PD 130
    Dec 2009
    Waterlooville U.K.
    12 Post(s)
    Where can I get oil at 20/5L ?
    0 2 0
  8. Re: Oil change interval PD 130
    Oct 2012
    Cardiff, Wales
    I do my ASZ PD 130 every 8k with 5W40 fully synthetic PD oil from Europarts / Car Parts for Less and it's never missed a beat. Now on 120k.
  9. Re: Oil change interval PD 130
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    Quote Originally Posted by vwcabriolet1971 View Post
    Trade Parts Specialist. Brilliant they are. 20L Quantum LL3 5w/40 is 45ish last week. 17.99 for 5L and 4.60 for 1L.
    Would definitely advise it regularly, changing camshaft costs a lot more and that was doing it myself... if your car was on long life service like mine to begin with, lift rocker cover and check camshaft if I were you. Lol.
    Aidan
  10. Re: Oil change interval PD 130
    May 2012
    Somerset
    204 Post(s)
    30 grade for the last two posts .
  1. DSG oil change interval
    By stevie5tapes in forum Golf MK6 - 2009-2013
    Last Post: 15-02-2016, 07:08 PM
  2. Oil Change Interval Display
    By mikegbingham in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-09-2009, 06:43 PM
  3. Cam belt change interval
    By harry6854 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2009, 09:38 AM
  4. cambelt change interval on 110 gt tdi?
    By andy-b in forum Golf MK4 - 1999 - 2004
    Last Post: 03-02-2008, 10:21 PM
  5. cambelt change interval
    By jezzaxt in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-09-2006, 10:09 AM
