Thread: Changing A4 B7 Symphony II Headunit
  1. Changing A4 B7 Symphony II Headunit
    Apr 2017
    Gloucestershire
    Had out A4 just under 4 months and the standard headunit is rubbish (putting it nicely, you can hear it clipping on vol 19-22). its the one with the 6CD changer and Tape player (double dim)
    Whats the best way to swap it out and put a single dim headunit in (i have a spare on ready just need to know what wiring i need to buy.) Or do i need to use a double dim headiunit?
    Newp
  2. Re: Changing A4 B7 Symphony II Headunit
    Apr 2017
    Gloucestershire
    anyone?
  3. Re: Changing A4 B7 Symphony II Headunit
    Sep 2017
    Schweinfurt, Germany
    I found some pretty cheap single din adapters at the "local" stereo shop, like less than 15 Euro...the wiring was 10(I think?). If you have steering wheel controls, and want to keep the basics, then you will need the adapter, which I think was 30, so the most expensive part. Altogether, I paid around 60 Euro to sub my single into the double slot....but I also did a bit more than just new radio. If you don't care about the steering controls, all you need is the din adapter and the wiring...unless you also don't care about the wiring, just cut it and wire direct. All depends on how you feel about possible selling the car later. I wanted to be able to put all factory parts right back in, so bought all the adapters, for less than 60 Euros. I t was also pretty straight forward for the install, but setting the steering controls was tricky. I can go in depth on that if you need it.
  1. symphony headunit. need to replace
    By bluegrass in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-04-2016, 10:35 PM
  2. Symphony 2 headunit
    By kodkod.84 in forum In Car Entertainment
    Last Post: 14-04-2014, 03:11 PM
  3. 56-plate Passat - changing headunit
    By fat controller in forum In Car Entertainment
    Last Post: 15-03-2011, 09:23 PM
  4. Changing Concert 2 Tape Headunit for CD Headunit
    By bigbigapple in forum Audi A3 - Archive Topics
    Last Post: 05-02-2009, 10:12 PM
  5. help with fitting an amp and sub to f/f symphony 6 cd headunit
    By kingreg in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-03-2008, 09:10 PM
