Thread: A3 2.0 TFSi Engine Management Emissions Control Light / Timing Chain Replacement
  1. A3 2.0 TFSi Engine Management Emissions Control Light / Timing Chain Replacement
    Jul 2017
    South West London
    Hi All,
    Audi A3 - 2TFSi 200 RJ58 *** 83,000 miles.
    Help/ideas very welcome as in for a big, and potentially unnecessary bill.
    Diagnostics are saying crank and cam shaft position sensor, but both have been replaced by local garage as light is still on. They took a closer look today and have suggested that the timing chain needs replacing as it is loose. They lifted the cover off the side of the engine and there was a bit of movement when pushed with a screw driver.
    The garage is quoting £1k for parts and labour, and saying they may need to open up the engine to check the valves and replace the head if they do this. Seems excessive. Is it possible the a new chain and kit will fix the management sensor issue? The lambda sensor has not been checked yet and was thinking that might be sensible before?
    Car used to start fine, and since the light came on it turns over, but only after 2+ seconds instead of immediate. I only do 4k miles per annum. Not sure how a loose chain would affect the turnover. I've driven car when light is on and drives fine (apart from the slowish turnover).
    Cheers, Stuart
  2. Re: A3 2.0 TFSi Engine Management Emissions Control Light / Timing Chain Replacement
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    The timing needs to be checked correctly .Not with a screwdriver! This could be the issue as if timing is slightly out it would show as your fault.
  1. Audi A3 1.4 TFSi timing chain intervals?
    By 220TC in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-01-2016, 01:02 AM
  2. Emissions Workshop Engine Management Light
    By djkinetix250 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-04-2015, 05:29 PM
  3. 2010 (March) - 1.8 TFSI - Timing Chain or Belt?
    By _tones in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-12-2013, 06:58 PM
  4. amber engine management light, emissions garage message on dash
    By phatagrova in forum Jetta MK3 - 2005 - 2013
    Last Post: 04-08-2013, 09:27 PM
  5. Please Help Emissions Workshop + Engine Management Light
    By R_FLIZ in forum Golf MK4 - 1999 - 2004
    Last Post: 20-05-2008, 09:40 AM
