Thread: Window stopped working via fob
Results 1 to 10 of 14
  1. Window stopped working via fob
    May 2017
    GB
    Hi.
    Recently had a flat battery and since then the windows and sunroof don't go up/down via the fob anymore.
    Can somebody please shed some light as to what the possible issue use and a solution.
    I read that they may need re programming if so does anyone know of a place in Birmingham.
    Sent from my SM-G935F using Tapatalk
  2. Re: Window stopped working via fob
    May 2013
    Wisbech
    What year a8 do you own ? Is option in mmi set to 'yes' ?
    Sent from my Nexus 6P using Tapatalk
  3. Re: Window stopped working via fob
    May 2013
    Wisbech
    If you press button inside car (driver door panel)are all windows going down automatic or you have hold button until fully open ?
  4. Re: Window stopped working via fob
    May 2017
    GB
    Quote Originally Posted by damtom85 View Post
    2005. Went into mmi and into setup and Windows and everything is as it was b4 ie yes is selected in convenience opening.
  5. Re: Window stopped working via fob
    May 2017
    GB
    They all go down on Automatically as b4
  6. Re: Window stopped working via fob
    May 2013
    Wisbech
    Did u try to open windows with key inside driver's lock and keep it in unlock position , is there any reaction from windows ?
  7. Re: Window stopped working via fob
    May 2017
    GB
    Haven't tried this. I'll have a crack at at now and report back.
  8. Re: Window stopped working via fob
    May 2017
    GB
    I put the key in the driver side door lock and held the unlock button. Nothing happens
  9. Re: Window stopped working via fob
    May 2013
    Wisbech
    Put key in lock and twist key and keep in unlock position(old fashion way of opening car without cetral locking) . I'm not sure in your A8 which way is unlock , left or right , but try first unlock and lock car with key in driver lock. You should keep key in unlock position up to 5-6 seconds and windows should go down .
    Also if you leave windows open can you close them with remote ?
  10. Re: Window stopped working via fob
    May 2017
    GB
    Kool. I'll try this again.. the windows don't go up or down with fob anymore.
  1. Drivers Window Stopped Working
    By djdreamer in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2011, 02:54 PM
  2. window washer stopped working
    By scootermap in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-12-2010, 05:56 PM
  3. Tt drivers side window stopped working
    By BIGSSS in forum TT - 8N Forum - 1998 - 2006
    Last Post: 26-02-2010, 07:42 PM
  4. Window Switch stopped working!!!
    By JDale in forum Audi A3 - Archive Topics
    Last Post: 10-12-2008, 11:35 AM
  5. Nearside Rear Window has stopped working???
    By nemo2182 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-06-2007, 10:10 PM
