Thread: Horn - not fuse, not relay, not clock spring - not working!
  1. Horn - not fuse, not relay, not clock spring - not working!
    Jun 2016
    west yorkshire
    2011 Golf 1.6tdi S Bluemotion
    So the horn doesnt work - I have checked the fuse ( # 17 ) and swapped the relay for one off another car that the horn defiantly works
    An auto electrician put a energised the relay and the horn works - He tested the between the horn switch and the yellow plug at the back of the airbag and he says that the fault is between that plug and the relay.
    I swapped the clock spring off an identical spec car which I know the horn works and the clock spring off the faulty horn car works fine on the other car.
    so now I am down to the fault been between the wiring after the clock spring and the relay.
    I am starting to think that the fault is in the relay board - has anybody got any ideas ??
    The fault code is 'control for signal Horn 009 - open or short to ground'
  2. Re: Horn - not fuse, not relay, not clock spring - not working!
    Dec 2007
    8 Post(s)
    Did the auto elec. person say it was an earth signal from switch that was missing.
  3. Re: Horn - not fuse, not relay, not clock spring - not working!
    Jun 2016
    west yorkshire
    Yes - he did say it was showing +0.5V for some bizarre reason which to me seamed to indicate it might be a fault in a control unit rather than a break in a wire, but I arent an electrician
    (the guy who looked at it did it as a favour in his break from work so couldn't look any further into it)
  4. Re: Horn - not fuse, not relay, not clock spring - not working!
    Dec 2007
    8 Post(s)
    May not be any help,but my A3 wiring diagram shows the horn cables as one to earth,and other to relay.
  5. Re: Horn - not fuse, not relay, not clock spring - not working!
    Jun 2016
    west yorkshire
    Thanks for your help Michael - I have just sorted it - there was a break in the wiring where it goes over the steering column near the peddle box
  6. Re: Horn - not fuse, not relay, not clock spring - not working!
    Dec 2007
    8 Post(s)
    Thats good, was it brown,or brown with tracer colour
  1. Centering/Aligning Clock Spring
    By Skezza in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2016, 03:36 PM
  2. Please Help Q3 2013 clock spring ETKA part number
    By Audidua in forum Q3
    Last Post: 30-12-2014, 08:30 AM
  3. How To Replacing clock spring on airbag.
    By emmbeedee in forum Alhambra
    Last Post: 17-11-2009, 05:57 PM
  4. airbag , clock spring removal advise
    By jamesey in forum Touran - Sharan - Caravelle
    Last Post: 06-01-2009, 10:54 PM
  5. Question lt35 horn relay
    By Dunk in forum The Commercial Range
    Last Post: 15-06-2008, 12:28 AM
