Thread: Vibration from dash around driver
Results 1 to 10 of 15
  1. Vibration from dash around driver
    Jun 2016
    Wolverhampton
    I've got a 2017 A6 Avant BE 3.0 and recently have been getting a vibration from somewhere in the dash in front of me. It's worse on rough roads and with the air suspension is dynamic mode.
    I thought I'd found it by taking the fuse box cover off at the drivers door end of the dash but that's not it.
    It sounds like it's directly in front of me when driving and is sending me insane. I'm due a service in a month or so and trying to hold out until then, but wondered if anyone has found and fixed a similar issue?
  2. Re: Vibration from dash around driver
    Feb 2016
    Hungary
    113 Post(s)
    Try to hold and push the cup holder's cover when you feel the vibration, as it could make such annoying noise.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  3. Re: Vibration from dash around driver
    Mar 2014
    United Kingdom
    33 Post(s)
    Do you have the Head Up Display? They are known to rattle. Mine does...
  4. Re: Vibration from dash around driver
    Sep 2009
    Preston
    54 Post(s)
    Same here - HUD rattle.
    From Apr 2017 - now: Oct 2016 (66) Audi A7 3.0 TDI quattro (FL - MY17), 272 ps, Black Edition (Tech pack, Parking Pack, Folding Mirrors), Mythos Black.
    Gone - From Oct 2013 - Mar 2017:
    Mar 2013 Audi A6 C7 S-line 2.0TDi Manual, Daytona Grey.
    (Gone) - From Sep 2011 - Oct 2013
    : Sep 2010 Audi A6 C6 S-line Special Ed (Le Mans) 2.0 TDi Manual, Polar Blue./(Gone) - From Sep 2009 - Sep 2011: Sep 2008 Audi A6 C6 S-line 2.0 TDi Auto, Akoya Silver.
  5. Re: Vibration from dash around driver
    Jun 2016
    Wolverhampton
    Thank you. No HUD on my car and not the cup holder cover. It seems right around the clocks in the dash and is a real metallic resonating vibration. If I get to the service and Audi can't fix it either, the answer will be a can of petrol and box of matches it's so annoying
  6. Re: Vibration from dash around driver
    May 2008
    Yorkshire
    I've just solved a similar problem. It was the speaker grille on the dashboard. Apparently it is a known issue and a updated part is available to resolve it rather than felt packing.
    Hope you find your rattle. They drive you nuts.
    2020 B9 A4 Avant Black Edition S Tronic
    2016 FL C7 A6 Avant Ultra Black Edition S Tronic | 2015 FL C7 A6 Avant Ultra Black Edition - S Tronic
    2012 B7 A4 Avant SLine |2008 B7 A4 Avant Sline | 2008 VW Golf PD150 GTI | 2007 VW Golf PD150 GTI
    2004 B6 A4 Avant Sport | 2000 A3 1.8T Sport | 1983 VW Golf GTX
  7. Re: Vibration from dash around driver
    Jun 2016
    Wolverhampton
    Thanks - that's a great steer to check out. Centre one or tweeter at the side by the door pillars. How did you prove where yours was?
  8. Re: Vibration from dash around driver
    May 2008
    Yorkshire
    Centre dash - the big grille. It was a tricky one to find. Ended up getting a mate to hold various bits of trim whilst driving around. Audi replaced the grille for the updated one without question.
  9. Re: Vibration from dash around driver
    Jun 2016
    Wolverhampton
    Thanks for the help but I'm now sure it's not the speaker grille in my case.
    I thought I had it sorted by adjusting the steering wheel height a smidge, but yesterday it was back after about a week of no vibration.
  10. Re: Vibration from dash around driver
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Noises in cars can be notoriously difficult to trace. Best bet is to use an old piece of hose pipe and a funnel, or just the hose on its own, to help isolate other noises. Put one of the hose to your ear and point the other to the direction where you think the noise is coming on and then let the hunt begin! This should then help a passenger to home in on the source of the rattle. Saturday Mechanic: Hushing Interior Squeaks And Rattles
    I had an annoying knock in a previous car that I could have bet my right arm was coming from the seat belt mechanism above my right ear....turns out it was something completely different on the other side of the car!
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  1. Bluetooth Problems & Vibration behind the dash...
    By bluestar_ale in forum Passat - B8 Forum - 2015 -
    Last Post: 02-01-2017, 03:30 PM
  2. Vibration
    By f2raf in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-06-2011, 05:19 PM
  3. 1.9 tdi 90 hp b5 vibration
    By mudoje in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2010, 04:10 AM
  4. Question Vibration
    By jgoodman00 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-11-2009, 06:05 PM
  5. Clicking noise in A6 Dash driver side Help!?
    By lilros82 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-01-2009, 01:00 PM
