Thread: Give me stength
  1. Give me stength
    108 Post(s)
    1816 Post(s)
    Since last week I have been trying to find the reason for an odd current drain on a type 36 Passat through fuse SB7 for the radio, 1.5amp constant with the car shut down and locked. This happens on early PQ35 (Golf 5) platforms when the CAN BUS doesn't like a later radio and a new CAN BUS sorts it. This car is 2011 and should not have the issue, I have spent hours on it and been through the circuity with a fine tooth comb and found nowt except the radio must be out of another car as the soft coding is all wrong so I wondered if that could be causing the drain. I tried to recode this in VCDS but it were avin none of it so I got the OK to spend 10 euro for an hour on the VAG system ODIS and that would not cooperate either so it became reasonable to think it was the radio at fault so the owner gave me the radio out of his T5 and I tried that, now a 1amp drain, which is odd. I spoke to him about this today but came to no conclusion. About 10 minutes later he called back and said somthin along the lines of “month ago car flat battery I use lead from T5 jump and when turn around have fires at battery do you think this could be something?
    i'm goin ohm ......
    0 3 0
  2. Re: Give me stength
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    Probably lost something in translation ��
  1. Please Help about to give up
    By Dilksy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-10-2015, 08:26 AM
  2. Give me the low down
    By Tony_N in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-04-2015, 10:01 PM
  3. Give your car the flu jab!
    By Y90USF in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-11-2012, 04:54 PM
  4. somebody..anybody help before i give up
    By carah in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2012, 09:19 PM
  5. Do you give your car a name.
    By pon in forum Chat - Completely Off Topic
    Last Post: 29-06-2009, 07:19 PM
