Thread: Why wont these wheels fit
Results 1 to 9 of 9
  1. Why wont these wheels fit
    Feb 2015
    GB
    I had these wheels on my mk5 golf
    And they will not fot on my b7 avant.
    The wheels fit not problem
    The issue the holes dont match up.
    Holes on the hub seem further away from the centre, where as the holes on the wheel seem closer to centre ..so when i line the holes up i cant get the bolt in as the holes are slighly overlaping
    ..again i thought audis and vw both had 5x112 stud pattern, so they should fit my audi
    Picture shows same wheels, black are mine and i had these on the golf
    Silver is from the internet showing a better image of them
    They are called Nuvolari
    Any help?
    Sent from my SM-G900F using Tapatalk
  2. Re: Why wont these wheels fit
    1840 Post(s)
    A Golf 5 (type 1K) and your A4 (type 8E) are both 5x112 M14 so something doesn't make sense. Is there are VAG part number on the wheel under the cap?
  3. Re: Why wont these wheels fit
    Feb 2015
    GB
    Think mine are reps
    But 100% fit straight to my golf
    It has me so confused lol
  4. Re: Why wont these wheels fit
    1840 Post(s)
    Could your Golf have had adapters on?
  5. Re: Why wont these wheels fit
    Feb 2015
    GB
    Quite possibly
    But i got some audi rotors put on the golf and they went on no problem.
  6. Re: Why wont these wheels fit
    Feb 2015
    GB
    Here is a quick drawing lol
    Clear circles are holes on the hub
    Darker circles are holes on the wheels
    As you can see they are same position just not right distance
  7. Re: Why wont these wheels fit
    Aug 2017
    US
    Is the car jacked up high enough? It seems u are hitting the ground w/o knowing it and trying to come on at a angle.. trust me..ive been there
    Sent from my SM-G920V using Tapatalk
  8. Re: Why wont these wheels fit
    Sep 2017
    Schweinfurt, Germany
    Maybe something is aftermarket on the B7. All of my rims fit B6+7, 4B+C(A6), MK4, MK5....no issues. Hell, they even fit the D3 A8.
  9. Re: Why wont these wheels fit
    May 2009
    Glasgow
    Wheels look like the older 5x100 pcd. I'm guessing the golf has adapters fitted to accept the older vag wheel pattern.
    Centre of rotation (hub) to center of stud 50mm for old vw and 56 for newer
  1. Can I change 18 inch wheels for 17 inch wheels?
    By dln6376 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-03-2014, 09:49 AM
  2. Replies: 1
    Last Post: 11-03-2013, 08:20 PM
  3. Boot Wont Open& Rear Wiper wont work...HelPPP
    By mohammedpatel in forum Golf MK5 - 2004 - 2009
    Last Post: 17-09-2009, 05:54 PM
  4. Boot wont open! fuel flap wont lock!
    By 2rabbits in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-03-2009, 02:28 PM
