Thread: A7 Quattro front to rear tyre wear tolerances
  1. A7 Quattro front to rear tyre wear tolerances
    Sep 2016
    Devon
    33 Post(s)
    Had a call today from my Audi dealer. Car is on for 38k service 64 plate.
    Front tyres are 6mm and tears are 3.5mm
    Although they are legal the tech is stating that there is a 2mm tolerance between the front and rear which if not adhered too could cause esp/abs issues
    I find this hard to believe that 0.5mm in wear would affect performance? Considering the fronts always wear faster within 90 days they'll be in tolerance
    What do people think?
    Andy
    Sent from my iPhone using Tapatalk Pro
  2. Re: A7 Quattro front to rear tyre wear tolerances
    Mar 2017
    Barnet, London
    6 Post(s)
    Is he an ex Formula 1 technician?
    Although a more worn tyre has a slightly smaller circumference. But surely we're not going down that route? Probably more issues around different tyre pressures/road surface etc to worry about.
    Just my opinion anyway (although changing the rear set is pretty darn close - there are some threads on here with good deals)
  3. Re: A7 Quattro front to rear tyre wear tolerances
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Quattro experts may know better but AFAIK having different rolling circumferences front and rear makes the centre diff work harder than it needs to, 2mm tolerance so you're just over at 2.5 mm for a thousand miles or so until the front wear down, maybe no problem. I suspect a long high speed motorway run would make the diff work hard and run hotter than usual, knocking round the doors less so.
  4. Re: A7 Quattro front to rear tyre wear tolerances
    May 2012
    Everywhere
    308 Post(s)
    I think the rears would wear faster than front because of the quattro 60/40 split .
  5. Re: A7 Quattro front to rear tyre wear tolerances
    Sep 2016
    Devon
    33 Post(s)
    I've replaced fronts at 32k car has traveled 37k now so I'm sure I'll get another 10k from the rears. Personally I don't think the .5mm makes any difference. Cheers
  6. Re: A7 Quattro front to rear tyre wear tolerances
    Jul 2011
    St Neots
    18 Post(s)
    i suspect the 2mm is rubbish. 5psi air pressure could make that difference too, or a a heavy load in the boot.
    S6 Black Avant: Tech advanced, Matrix, Keyless entry, Sunroof, Speed limit display, Tow bar, Rear camera
    Golf GTI (for the Mrs) BMW M140i (for work and fun )
  1. Question A3 Quattro rear tyre wear
    By BAZ911 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-01-2017, 05:23 PM
  2. Quattro front/rear tyre wear?...
    By M3 Compact in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-11-2012, 07:21 PM
  3. Question a4 quattro 3.0tdi excessive front tyre wear
    By ads8562 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-02-2012, 05:33 PM
  4. Question A3 Quattro: Rear Tyre Wear
    By dunkjnr in forum New Member Introductions
    Last Post: 06-06-2010, 10:38 AM
  5. A4 2.0 TDI Quattro Tyre Wear
    By crp28 in forum Archive posts
    Last Post: 11-02-2008, 01:14 PM
