Thread: Whistling noise after new egr fitted. Turbo?
  1. Whistling noise after new egr fitted. Turbo?
    Sep 2007
    Norwich, Norfolk, United Kingdom
    I've just had a new egr fitted by a trusted independent on my 2011 passat 1.6 tdi bluemotion estate. I have not had the emissions update done to my car and have no plans to after joining a very informative Facebook group. Sadly, the egr failed T 70k ish which is why I had it replaced. I have been driving for a couple of days with the egr and everything seemed normal but on Friday, I started hearing a whistling noise from the engine when pulling away and also when first applying throttle. It's more noticeable when moving and when the engine is warm. It also does it when reversing. I called my mechanic and am taking it back tomorrow but trying to work out what it could be and whether I can expect more bad news. Any thoughts?
  2. Re: Whistling noise after new egr fitted. Turbo?
    Norfolk
    Whistling is usually an air or vacuum leak so should be easy to fix if they can find it.
  1. Turbo whistling noise???
    By jasw in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-02-2017, 12:57 PM
  2. Turbo whistling and slight dump noise....
    By Sebseb in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-11-2013, 04:27 PM
  3. Question Turbo Whistling Noise
    By P4LI in forum Golf MK4 - 1999 - 2004
    Last Post: 08-10-2010, 04:31 PM
  4. Whistling Noise
    By bleasy in forum Golf MK4 - 1999 - 2004
    Last Post: 04-04-2009, 07:32 AM
  5. Whistling noise from n/s rear when changing gear.. Common noise in all PASSATS ??
    By Gaz_2005_Passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-12-2008, 06:46 PM
