Thread: VW Passat 1.9 TDI Poorr starting
Results 1 to 10 of 19
  1. VW Passat 1.9 TDI Poorr starting
    Jul 2017
    Inverness
    I have a 2001 VW Passat 1.9 tdi. It starts OK when the engine is warm or when the weather is warm, but if it has been lying a few days or it's cold weather, it won't start without a jump or bump. I've changed the glow plugs so it's not them. Anyone got any idea what I can try next? Battery and alternator are both good, by the way.
  2. Re: VW Passat 1.9 TDI Poorr starting
    negev Guest
    You'll run out of money before you run out of guesses :P have it diagnosed.
    0 2 0
  3. Re: VW Passat 1.9 TDI Poorr starting
    Jan 2009
    Birmingham
    35 Post(s)
    You could try coolant temp sensor
  4. Re: VW Passat 1.9 TDI Poorr starting
    Oct 2016
    Ipswich UK
    My pd130 started perfectly when the cts sensor was totally kaput, and no different when a new one fitted, so I would discount that.
  5. Re: VW Passat 1.9 TDI Poorr starting
    Jul 2015
    Staffs
    46 Post(s)
    I guess that depends what was wrong with, and the readings it was supplying to the ECU .
    OP what happens when you try to start it from cold?.....just turns over? Or not at all?
    Ian
    A4 B6 Avant Nogaro Blue
  6. Re: VW Passat 1.9 TDI Poorr starting
    Jul 2017
    Inverness
    It turns over but won't start. The battery flattens pretty quickly and then all sorts of things happen. Alarm goes off and the tailgate unlocks. I park on a brae (hill) and bump-start it on those days, and it starts no bother that way
  7. Re: VW Passat 1.9 TDI Poorr starting
    Oct 2016
    Ipswich UK
    Which suggests your battery is at the end of its life.
  8. Re: VW Passat 1.9 TDI Poorr starting
    Jul 2015
    Staffs
    46 Post(s)
    Could be air getting in to the fuel lines.
    Ian
  9. Re: VW Passat 1.9 TDI Poorr starting
    Dec 2007
    8 Post(s)
    Try cleaning battery terminals and posts with sandpaper,also the earth at engine / gearbox.
    Is it possible to try a known good battery to see if problem still exists.
    Another thing to try is removing earth connection from battery when parking for a long period,this would be to see if you have a battery drain.
  10. Re: VW Passat 1.9 TDI Poorr starting
    Jan 2009
    Birmingham
    35 Post(s)
    When was the cambelt last changed?
    get someone with Vcds and check the torsion value It could be out and causing poor starts
    http://www.myturbodiesel.com/wiki/ca...d-tdi-engines/
  1. Passat 2.0 BKD not starting
    By diag1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-07-2015, 01:17 AM
  2. Passat B6 Non starting
    By nashyn in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2015, 08:41 AM
  3. Passat not starting
    By Berkshire_Boy76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-08-2010, 07:58 AM
  4. Please Help Starting problem 06 Passat
    By squashabe in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-04-2010, 10:56 PM
  5. passat not starting
    By Brainscram in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2007, 11:42 AM
