Thread: Seat Altea Climate Control Problem
  1. Seat Altea Climate Control Problem
    May 2017
    I have a 2007 Seat Altea 1.9tdi with BXE engine when I turn on the climate control it works for a few seconds then seems to switch itself off. Occasionally I can hear ticking noise coming from under the glove box. My mechanic has put his fault finder on the car but no faults show up. Any ideas what the problem could be?
  2. Re: Seat Altea Climate Control Problem
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    sounds like your flap motor is trying to work then cutting out, you don't say what the mechanic used to diagnose the fault but someone with vcds could probably run a scan and pick up any codes in the relevant control module. have a look at this thread, I know it's old but might give you an idea where to look for the motor.
    Please Help The dreaded climate control click - Page 2
  3. Re: Seat Altea Climate Control Problem
    May 2017
    Thank you Rob69 for your help. What is the name of the part that I need and the part number.
  4. Re: Seat Altea Climate Control Problem
    Nov 2010
    104 Post(s)
    I don't know the part number and you should confirm it is the motor at fault first, this seems to be a common fault though and if you search online i'm sure you'll find how other folks fixed it.
  5. Re: Seat Altea Climate Control Problem
    May 2017
    It was definitely the recirculation flap motor. Looked online how to change this but could not find any for the Altea except VW cars which seemed easy enough so decided to try it myself. Got the glove box out easily enough but have now run into a problem I can't get the actual motor out because part of the cars structure that the glove box screws into is stopping the motor from coming out. How do I get the motor out?
  6. Re: Seat Altea Climate Control Problem
    May 2017
    Today spoke to my mechanic friend he said that the dash may need to come out in order to sort the fitting of new recirculation flap motor. Is this true?
  1. Climate control problem
    By dodderz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-11-2014, 10:46 AM
  2. Please Help Climate Control Problem.
    By Yeadonchap in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-09-2011, 09:19 AM
  3. climate control problem
    By tpb234 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-02-2010, 05:35 AM
  4. Please Help Climate control problem
    By dpsmith02a4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2009, 11:03 AM
  5. climate control problem
    By dc2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-05-2008, 09:28 PM
