Thread: Q5 suspension conversion
  1. Unhappy Q5 suspension conversion
    Jan 2015
    Myrtleford Australia
    I desperately need to soften the suspension on my 2015 Q5 fitted with 17" wheels and adjustable dampers. My wife has a bad back and the ride is too rough on Australia's bad roads. Has anyone fitted air suspension and if so how much difference does it make. Thanks.
  2. Re: Q5 suspension conversion
    Jul 2017
    West Midlands
    Quote Originally Posted by linleeridge View Post
    The harsh ride isnt coming from the Springs so changing the Springs to Air springs wont help much , it is the shock making the ride hard and its a common problem on modern cars . In an attempt to get the cars to handle well , comfort is always compromised . there is only one shock that can sort out this problem . KONI FSD go to www.toperformance.co.au and try to speak to or get hold of Barry Brookes he will sell you a set and explain why they are so good , If not ill send you a tech explaination , I also had a client in S Africa who had a bad back and couldnt believe the difference fitting these parts made to his Kia Sorento that spent a lot of time off road , Steve
  3. Re: Q5 suspension conversion
    Jul 2017
    Buffalo River Australia
    Thanks crsperformance for your comments. Car salesmen (not always reliable) would tell me that air suspension would definitely help. However if what you recommend would solve the problem my concern is that my vehicle is fitted with the adjustable damper option (i.e. comfort, sport, dynamic settings etc). If new shocks were fitted dealers tell me it may interfere with other settings on the adjustable damper option. Not sure if this model would work. I will make the contact as you suggest when I come back from holidays in around 4 weeks and go from there. Cheers.
  1. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  2. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  3. anyone done the arnott allroad suspension conversion?
    By Fantombiker in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-01-2011, 02:25 PM
  4. S Line suspension vs Sports Suspension - Retro fit
    By scoobmw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-10-2010, 09:23 AM
  5. Mechanical differences between Sport suspension and ordinary suspension
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-06-2010, 05:03 PM
