Thread: Voltage fault caodes - alternator problem?
  1. Voltage fault caodes - alternator problem?
    Mar 2007
    Devon
    I've just bought a 2007 A3 2.0 TDI 170. I've had it scanned and its come up with a few fault codes, may of them voltage related. I read somewhere it could be related to the alternator failing. Can anyone confirm this. Thanks in advance for any help.
    Chassis Type: 8P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WAUZZZ8P47A119545 Mileage: 232310km/144350miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 1247
    Revision: --H32--- Serial number: AUX7Z0FNFNG07A
    Coding: 0000078
    Shop #: WSC 66565 257 00032
    VCID: 74E73A5B174EF4BE80B-8021
    1 Fault Found:
    009766 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit
    P2626 - 008 - Open - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10101000
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 40
    Mileage: 232086 km
    Time Indication: 0
    Date: 2017.07.01
    Time: 13:24:30
    Freeze Frame:
    RPM: 1312 /min
    Torque: 0.0 Nm
    Text: 31.88
    Text: -0.04 V
    Voltage: 4.20 V
    Text: 784 C
    (no units): 108.0
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Shop #: WSC 60677 001 1048576
    VCID: 73E539471240F386991-8026
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H13 4260
    Revision: 91H13426 Serial number: 003620G2Z1S7
    Coding: 0071612
    Shop #: WSC 06314 000 00000
    VCID: 428BAC831D7A0A0EC27-8017
    Subsystem 1 - Serial number: 6332DRB40446451BI
    Subsystem 2 - Serial number: 6342DRB4044612AFQ
    Subsystem 3 - Serial number: 63528RB401D52E4FY
    Subsystem 4 - Serial number: 63628RB401D93F33S
    Subsystem 5 - Serial number: 63729RB401D8FC1B1
    Subsystem 6 - Serial number: 63829RB401D8FBEFI
    1 Fault Found:
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 38
    Mileage: 232040 km
    Time Indication: 0
    Date: 2017.06.29
    Time: 13:38:07
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 224NF004007552
    Coding: 0000418
    Shop #: WSC 00411 067 57207
    VCID: 3B75D1677A907BC6811-806E
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 232040 km
    Time Indication: 0
    Date: 2017.06.30
    Time: 10:57:18
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Component: Tuer-SG 020 0090
    Coding: 0000688
    VCID: 4189A38F187C1116DBD-8014
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
    Component: R Symphony2+ H14 0220
    Revision: 00H14000 Serial number: AUZ1Z4F9004654
    Coding: 0010301
    VCID: 3663C05341B2A6AE7EF-8063
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 15
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 232040 km
    Time Indication: 0
    Date: 2017.06.30
    Time: 10:57:18
  2. Re: Voltage fault caodes - alternator problem?
    May 2008
    Norfolk
    Looks like your battery has been flat at some point, most of those codes can be erased.
    Sold - 07 A3 Sport Sportback 170 DSG
    Sold - 11 A3 S-Line Sportback 170 DSG
    Sold - 57 A3 Sport 170 DSG
    Sold - 60 A3 Technik 1.6 Manual
    Current - A3 S-Line 2.0 DSG Cabriolet
  1. Alternator - is voltage regulator replaceable?
    By Dohnut in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-01-2015, 02:40 AM
  2. Fault code 001619 - Sensor Reference Voltage B
    By Eds_taff in forum VCDS - Help Requests
    Last Post: 03-08-2013, 04:56 PM
  3. Passat 5.5 AWX fault codes on airbags and central locking...voltage related!!??
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2012, 07:50 PM
  4. seat leon fault code 16947 system voltage too high?
    By yas_b in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 30-03-2010, 11:37 PM
  5. Fault Code 00532 Supply Voltage
    By nomoretears in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-11-2009, 06:00 PM
