Thread: Help please. Brakes wont bleed.
  1. Help please. Brakes wont bleed.
    I have a VW Eos 2.0 TDI and I am unable to bleed brakes after fitting master cylinder, I have borrowed my work colleagues Snap On verdict to help bleed by following the instructions on the tool, but after going through the sequence 4 times, I still have no brakes. During the bleed process it says that the brake pedal will slowly sink and then the ABS will pump it back up but this doesnt happen. At no time does the pedal go to the floor. I am left with a normal feeling pedal but no brakes. what am I doing wrong?
  2. Re: Help please. Brakes wont bleed.
    Oct 2017
    My best friend for brake/clutch bleeding when the bleeding process is problematic and sometime this happened, is a ... cooling pressure test kit, this kit have a pump and one cap fit on the brake fluid reservoir, give just a little pressure and pump the brake, first i do just the master cylinder, plugging the holes with my fingers (using gloves of course), after that I do plug the pipes, bleeding on calipers.
    Time a go, in other garage, we used a reservoir filled with brake fluid, plugged on brake fluid reservoir and a air hose connected on the wheel, the wheel pressure, thru the air hose, force the brake fluid to get into the brake fluid reservoir, helping the bleeding process.
  1. Bleeding brakes- bleed sequence
    By Sparky_143 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-06-2014, 10:12 PM
  2. Bleed Nipple
    By Peter D in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-04-2014, 08:35 PM
  3. How To Crikey, I only wanted to bleed the brakes.....
    By srad34 in forum Bora - 1998 - 2005
    Last Post: 30-04-2013, 08:06 PM
  4. How To Bleed Brakes on '90 Coupe quattro 2.3 10v
    By splitpin in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 12-10-2009, 10:37 PM
  5. vag- com abs bleed mode
    By cavanagh81 in forum VCDS - General Questions
    Last Post: 03-05-2008, 11:21 PM
