Thread: Allroad drivers window problem
  1. Allroad drivers window problem
    Jan 2011
    Falmouth UK
    Recently bought an allroad, slowly working through problems.
    The drivers window goes down fine, returns fine for the fires 1/4 then slows and stops at half closed.
    You can aid it up and get it fully closed.
    Spoke to previous owner, they have had the regulator replaced, then a while after the window wouldnt close, so they took it back to the garage and they said it needed adjusting.... anyway it then worked well again, all up antill the time I bought the car when it started to mess around again.
    Is there adjustment to the window?
    Or is it likely a duff regulator again?
  2. Re: Allroad drivers window problem
    Nov 2011
    Duns Scotland
    11 Post(s)
    ... probably dirty runners gathered over the years. Wind down window. Remove the two screws - one at either end of the interior door trim below window near hinge and lock. Push screwdriver up into the hole in the underneath of the widows switch to remove and disconnect. Now lift up the trim 8 inches and remove from door and release the door lock cable behind it. You can now move the trim away sufficiently to get at the window runners (just the wiring is left attached). Clean with rag and wd40 (or equivalent). Before reassembly, connect window switch and test the window raises and lowers smoothely.
  1. drivers window wont go all the way up - Allroad
    By dirtyben in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-12-2013, 09:02 PM
  2. Drivers window problem.
    By surgeon in forum Vehicular windows, Glazing and Tinting
    Last Post: 19-01-2013, 09:32 PM
  3. Please Help Drivers electric window problem
    By carlngem in forum Alhambra
    Last Post: 07-06-2009, 09:40 AM
  4. problem drivers window on Alhambra
    By anlorel in forum Alhambra
    Last Post: 09-06-2008, 10:29 PM
  5. '02 reg audi a4 drivers window problem
    By chrism9 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2008, 06:30 PM
