Thread: Vacuum thing on inlet manifold weeping oil
Results 1 to 10 of 11
  1. Vacuum thing on inlet manifold weeping oil
    Oct 2016
    Ipswich UK
    Greetings, there is a vacuum thingy on top of the inlet manifold and it is weeping a tiny amount of oil, is this a common failing? Is it likely to get worse? As it is, it is only a trace, but I would not like it to get worse.....Ta!
  2. Re: Vacuum thing on inlet manifold weeping oil
    Dec 2014
    Bedford
    42 Post(s)
    Diesel? Left side? Got a picture of it?
  3. Re: Vacuum thing on inlet manifold weeping oil
    Oct 2016
    Ipswich UK
    Sorry should have said- pd 130 TDI AWX. Will sort a pic soon, ta.
  4. Re: Vacuum thing on inlet manifold weeping oil
    Oct 2016
    Ipswich UK
    Quote Originally Posted by MrPassat02 View Post
    Picture now attached
  5. Re: Vacuum thing on inlet manifold weeping oil
    May 2012
    Everywhere
    308 Post(s)
    Probably the two atmospheric holes underneath egr actuator hat , which is normal .
    What year and plate ?
  6. Re: Vacuum thing on inlet manifold weeping oil
    Oct 2016
    Ipswich UK
    Quote Originally Posted by Gazwould View Post
    Its a 2002. So the gunge is just some sort of blowby from the egr system?
  7. Re: Vacuum thing on inlet manifold weeping oil
    May 2012
    Everywhere
    308 Post(s)
    Congratulations you can disable the egr without an eml .
    Plug them holes too .
  8. Re: Vacuum thing on inlet manifold weeping oil
    Oct 2016
    Ipswich UK
    I always wonder what the point of Egr is, and I guess the upside of blanking is less gunge in the inlet, but are there really no downsides to blanking it?
    Also what is the best way of blanking?
    Thanks!
  9. Re: Vacuum thing on inlet manifold weeping oil
    May 2012
    Everywhere
    308 Post(s)
    Technically you don't have to blank as a working egr is closed when off .
    To disable
    It's as easy as that .
    You could if desired fit a 1.5mm slip in blank at the base of the egr to prevent exhaust gasses from filling it .
  10. Re: Vacuum thing on inlet manifold weeping oil
    Oct 2016
    Ipswich UK
    Thanks! May well be worth doing as the car is a keeper especially now the alt pulley is done and with new thermostat mph is in the mid 50s... good motor.
  1. Solved Inlet Manifold Vacuum Actuator unit 3.0 V6 petrol Quattro
    By Narkdup in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2016, 07:01 PM
  2. Inlet manifold V6 TDI
    By hbsteer in forum Touareg
    Last Post: 03-03-2011, 07:13 PM
  3. Inlet manifold
    By mmeech in forum Golf MK5 - 2004 - 2009
    Last Post: 28-02-2011, 12:33 PM
  4. inlet manifold vacuum leak
    By king.lion in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-08-2009, 09:30 PM
  5. Oil on inlet manifold mk4 gt tdi 110
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2008, 06:57 PM
