Thread: Interior fan not working + 12v/cigarette lighter not working + sprayer not working + rear wiper not working
  1. Unhappy Interior fan not working + 12v/cigarette lighter not working + sprayer not working + rear wiper not working
    Jun 2017
    London
    Hi Guys,
    I am the happy new owner (and fairly new driver) of a usedmk5 1.9 TDI. Unfortunately, I quickly noticed that there were a series of an electrical malfunction. Complete list below:
    • Cigarette lighter
    • Fresh air blower
    • Front washer sprayer
    • Rear wiper
    • Rear washer sprayer
    After some research (thanks Google), it seemed clear that it was related to a relay, more precisely the 460. I ordered a new one, then battled for almost an hour to reach the relay and replace it. It hadn’t solved anything . The relay was actually fine.
    Can you guys point me out to any other potential solution/explanation before I bring the car to VAG??
  2. Re: Interior fan not working + 12v/cigarette lighter not working + sprayer not working + rear wiper not working
    Jun 2017
    London
    Hello, technical experts!!
    I am coming back, determined to solve this issue!
    For sure, my relays work. I can hear and feel the click when I turn the ignition. I've even inverted relays of positions B1 and B9. They both work.
    I checked with a multimeter and I noticed that there was no power on positions 40 and 41 (see fuses diagram here:Volkswagen Golf Mk5 fuse box diagram (1K; 2003–2009) » Fuse Diagram).
    Any idea on what I could do next?
  3. Re: Interior fan not working + 12v/cigarette lighter not working + sprayer not working + rear wiper not working
    Jul 2015
    Staffs
    46 Post(s)
    I assume youve double checked all the fuses? Other than that get a vcds scan.
    Ian
    A4 B6 Avant Nogaro Blue
  4. Re: Interior fan not working + 12v/cigarette lighter not working + sprayer not working + rear wiper not working
    Jul 2010
    Bradford, West Yorkshire
    As mentioned above, a diagnostic scan would help a great deal. as you have already changed the relay, the fault could possibly be in the central electrics module itself.
  5. Re: Interior fan not working + 12v/cigarette lighter not working + sprayer not working + rear wiper not working
    1840 Post(s)
    X relay failure (KL75) is a common issue but it is sometimes caused by failure of the ignition switch, have you have a full code scan carried out as a faulty switch normally comes up as a fault. 460 is the relay control group number. I can't help further than that from home as my ELSA PC is at work.
  6. Re: Interior fan not working + 12v/cigarette lighter not working + sprayer not working + rear wiper not working
    Jun 2017
    London
    Thanks all!
    The central electric module is indeed a good trail to follow. Same thing for the ignition switch but in that case, I have no idea how to approach the issue.
    I'll find a way to do a scan ASAP (I don't have the cable, but I have asked if someone located in East London may help on that).
  7. Re: Interior fan not working + 12v/cigarette lighter not working + sprayer not working + rear wiper not working
    Nov 2018
    Poole
    Did you ever get this fixed? I have the exact same issue on my 2007 golf
  1. Please Help rear wiper+cigarette lighter+heaters+parrot bt not working
    By ahsanx in forum Golf MK5 - 2004 - 2009
    Last Post: 08-10-2015, 07:54 PM
  2. Please Help Cigarette Lighter Not Working?
    By moh4mmedali in forum Golf MK4 - 1999 - 2004
    Last Post: 16-12-2009, 08:22 AM
  3. Cigarette lighter not working...
    By SB83 in forum Golf MK5 - 2004 - 2009
    Last Post: 07-01-2009, 11:34 PM
  4. t5 cigarette lighter-not working
    By criusboy in forum The Commercial Range
    Last Post: 03-09-2008, 10:21 PM
  5. Cigarette lighter not working - Engine & Oil temp gauges not working.
    By Shagger7 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 12:10 PM
