Thread: 2006 A6 Tdi Steering lock issue
  1. 2006 A6 Tdi Steering lock issue
    Dec 2007
    My car has developed the annoying steering lock module fault that seems to be common on A6's, put the key in the ignition MMI will come on and mileage but the ignition will not switch on. It initially did this around 4 months ago and i read online that the only fix is to replace the full column as the lock it is part of the column. I decided to have a look and it is not part of the column at all, it's bolted to it but not permanently fixed, remove 3 bolts and drill out a rivet and it's out.
    I sent the lock away to BBA reman who fixed the issue (a faulty actuator) and i didn't have a problem for 4 months, unfortunately in the last few weeks it has started to play up again, i get a fault code on the 05 module which needs to be cleared by Vag com and the car will start, it will be fine for a few days before doing the same again, carrying a laptop around with me to keep the car on the road is a little annoying!
    So i think i need to replace the module, i have seen lots of 2nd hand columns and lock modules for sale online but i have read that once they are coded, they cannot be recoded, is this correct or is also a false hood given by Audi as they want to sell you a column for £700+!
    Has anyone fitted a 2nd hand column to an A6 without issue? Does the lock module need recoding or will it simply bolt in? Any advice is greatly appreciated, i am close to scraping what is an excellent car other than this stupid fault!
  2. Re: 2006 A6 Tdi Steering lock issue
    Jul 2013
    76 Post(s)
    Are you sure it's not the ignition relay playing up.
    Do do a search for J629 relay.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: 2006 A6 Tdi Steering lock issue
    Dec 2007
    Quote Originally Posted by dan2485 View Post
    Thanks for that i've not checked, hopefully that's whats causing it!
  1. How To fix the issue of cranking sound that arise when steering on full lock to the right
    By sriramsg04 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-11-2016, 09:53 AM
  2. Electronic Steering Lock issue
    By Renesis in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-10-2014, 02:30 PM
  3. Replies: 0
    Last Post: 12-09-2014, 02:23 PM
  4. steering lock starting issue
    By csmccoll68 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-06-2012, 09:48 AM
  5. BKD intermittant non starter, immobiliser fault? And possible steering lock issue.
    By beelzibus in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-09-2011, 11:17 PM
