Thread: Strange groaning noise when turning at low speed
Results 1 to 10 of 14
  1. Strange groaning noise when turning at low speed
    Sep 2008
    Kildare,Ireland
    Hi guys
    I am getting an annoying groaning/rubbing noise when turning either way at low speed on my b7 2.0 tdi 2013 with 80k. Driving off on lock/reverse on lock. Does not happen with clutch engaged. Have been under the car and although I am no expert I can't see any oil,torn/worn boots, control arm bushings look good also, checked there was no rubbing against the dust guard. Any advice on this would be greatly appreciated.
  2. Re: Strange groaning noise when turning at low speed
    Sep 2008
    Kildare,Ireland
    Anyone?
  3. Re: Strange groaning noise when turning at low speed
    Jan 2016
    Winchester Hants
    29 Post(s)
    Maybe top up the power steering fluid.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  4. Re: Strange groaning noise when turning at low speed
    Sep 2008
    Kildare,Ireland
    Quote Originally Posted by UMEL View Post
    Hi.
    Thanks for the reply. If I am not mistaken the steering is electric so there is no fluid.
  5. Re: Strange groaning noise when turning at low speed
    Sep 2008
    Kildare,Ireland
    Anyone else any ideas? Have been searching google heavily to no avail. One point I have come across is the rear diff. Hopefully it's not that.
  6. Re: Strange groaning noise when turning at low speed
    Dec 2014
    Bedford
    42 Post(s)
    Record it and post it.
  7. Re: Strange groaning noise when turning at low speed
    Sep 2008
    Kildare,Ireland
    Quote Originally Posted by FLAPPERJACK76 View Post
    The sound is identical to the one in the link posted below.
    2012 VW Golf R - Brake Sound - YouTube
  8. Re: Strange groaning noise when turning at low speed
    Dec 2014
    Bedford
    42 Post(s)
    Like a mooing noise? I would check rear caliper sliders and it sounds like mk4 golf rear calipers before they fitted spring assisters to return the handbrake levers to rest. Check they are sitting at the rest point .
  9. Re: Strange groaning noise when turning at low speed
    Sep 2008
    Kildare,Ireland
    Yes it's as you say a mooing noise. Thanks for the reply. I will look into this.
    Ian
  10. Re: Strange groaning noise when turning at low speed
    1841 Post(s)
    Have the gearbox oil changed, this is a well documented problem with hypoid oil after high mileages causing the diff to groan.
  1. Strange noise when turning right
    By richtrash in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2014, 07:36 PM
  2. Noise from PS (?) when turning at low speed
    By Perfectgent in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-12-2011, 12:12 AM
  3. Strange noise coming from the front when turning to the right
    By sabikeuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-05-2011, 10:47 PM
  4. Question strange noise when turning
    By adam07 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-11-2008, 09:38 PM
  5. Polo - strange noise when turning/full lock right
    By Dreamertae in forum Polo - Derby - Lupo - Fox
    Last Post: 18-07-2007, 09:14 PM
