Thread: Longlife Oil change mileage
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Longlife Oil change mileage
    1840 Post(s)
    We have just about stopped using Platinum because it WAS not suitable for VAG vehicles with a DPF (even though it is marketed by VAG UK....) BUT now Quantum have chnaged supplier of Platinum from Castrol to Fuchs it is NOW suitable for VAG with DPF although to keep it simple I think we will just stick to LL3 in future on everything.
  2. Re: Longlife Oil change mileage
    Nov 2016
    Cardigan
    6 Post(s)
    Buuuuuut how do you actually get VCDS to change the computer to the long life setting, buggered if I can see how! Any pointers?
  3. Re: Longlife Oil change mileage
    Tripletrouble Guest
    As I want to do an inter oil change, would you say this - Castrol Edge Titanium 5w-30 LL FST Fully Synthetic Car Engine Oil, is the right stuff to use in my 190 Ultra?
  4. Re: Longlife Oil change mileage
    May 2012
    Everywhere
    308 Post(s)
    Yes one of loads of 507.00 oils about .
  5. Re: Longlife Oil change mileage
    1840 Post(s)
    Quote Originally Posted by Mintyjim View Post
    It can be a pain. In theory IF there is a menu in SRI this MAY work or get close with some tweaking being necessary in Adaptations BUT usually all the parameters have to be individually set up in adaptations 10 using the drop down menu and the MMI readout until you get the figures you are looking for. There are many variations and the later ones are complex plus you have to remember an Audi oil chnage is a VCDS service and an Inspection is a service, or is it the other way around, drives me nuts! The lads here can't get there heads around it so I have to do them all and if it is just a splash and dash oil chnage the coding can take longer than the job, stupid! I have an RS4 in today for a suspension kit, we serviced it two weeks ago and it has only done 100miles and the display still says ------ with no info.
  1. Question Interval vs Longlife Servicing - High Mileage Golf
    By richeymanic in forum Golf MK5 - 2004 - 2009
    Last Post: 03-01-2013, 02:36 PM
  2. How much for Kam Belt change and Longlife Service at 80,000 miles
    By russdeebrown in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-09-2009, 11:20 PM
  3. 1.8T oil change, quantum longlife 11 or 111
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-06-2009, 08:51 PM
  4. AUDI TT Oil Change - LongLife Service
    By CGS in forum Chat - Anything with wheels
    Last Post: 09-10-2008, 02:04 PM
  5. Replies: 6
    Last Post: 26-02-2008, 11:43 PM
