Thread: Key Battery Replacement
  1. Key Battery Replacement
    Dec 2015
    London
    13 Post(s)
    Can anyone advise on how to replace the battery in the key pls? Is it a straight swap, does it have to be re-coded, etc?
    One of my keys has stopped working.
    Thx
    J
  2. Re: Key Battery Replacement
    Nov 2009
    46 Post(s)
    straigth swap, pretty sure its a cr2026 battery
  3. Re: Key Battery Replacement
    Mar 2017
    Birmingham
    I have just replaced my keyfob battery, removed the key blade part and push the button to remove the button tray. Mine was a CR2032 and just worked as normal after.
  4. Re: Key Battery Replacement
    Mar 2017
    Barnet, London
    6 Post(s)
    I've used both - I think the only difference is the mAh. One will last longer than the other.
    After being caught out once - I always keep a spare in the glove box, for when it starts 'playing up'!
  5. Re: Key Battery Replacement
    Mar 2008
    11 Post(s)
    I've done a key fob swap with pictures not too long ago but it should help outline how to change the battery - scroll down to the pictures and it's essentially the black notch in picture 2 that you press down>pull out
    When you've inserted the new battery, take note of the red led at the top of the fob which should blink if you've put the battery in correctly
    Question Can the fob be dismantled?
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  6. Re: Key Battery Replacement
    Dec 2015
    London
    13 Post(s)
    Thanks, I found a utube clip, easy swap. battery on its way.
  1. 3.0 TDI Replacement battery
    By careless_adi in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-07-2015, 08:35 AM
  2. Please Help Key Fob Battery Replacement
    By JONES247 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-08-2008, 12:56 PM
  3. A6 battery replacement
    By Zeeblue in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-04-2008, 03:40 PM
  4. A3 1.6 battery replacement
    By Adpro2 in forum Audi A3 - Archive Topics
    Last Post: 07-02-2007, 04:50 PM
  5. Battery replacement on '99 A4
    By wanstronian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-09-2006, 04:40 PM
