Thread: Mk 6 golf 1.6 TDI aircon not working
Results 1 to 8 of 8
  1. Mk 6 golf 1.6 TDI aircon not working
    Mar 2012
    birmingham
    Just tried aircon button but its not working no cold air coming through also notice no noise from usual engine tone when its suppose to come on any ideas
  2. Re: Mk 6 golf 1.6 TDI aircon not working
    Mar 2012
    birmingham
    Just had the air-conditioning topped up but still no difference don't see the compressor engaging
  3. Re: Mk 6 golf 1.6 TDI aircon not working
    108 Post(s)
    1816 Post(s)
    You won't see the compressor engage, it is a permanent drive modulated displacement unit with no clutch. Have the system checked for fault codes, if there are non and you know the pressure is correct then it will need a new compressor or modulation valve but they are tricky to instal.
  4. Re: Mk 6 golf 1.6 TDI aircon not working
    Mar 2012
    birmingham
    Ok I thought it had a clutch the centre thread was out by about 5mm with either a torx or Allen key head on it thats what I thought maybe it had seized .the pulley turns but what looks like a clutch spins with it .i had taken the car to Halfords they topped it up free of charge but still no difference ,would the vag com or vcds diagnose the fault thanks
  5. Re: Mk 6 golf 1.6 TDI aircon not working
    Mar 2012
    birmingham
    Just had another look mines a clutch operated not the permanent drive modulated displacement unit
  6. Re: Mk 6 golf 1.6 TDI aircon not working
    Dec 2014
    Bedford
    42 Post(s)
    The fact the bolt is hanging out is whats wrong. It dont have a clutch its on all the time and even when its off its 2% duty cycled on. You could try tightening the torx bolt but its most likely to snap. Time for a new compressor is the best bet.
  7. Re: Mk 6 golf 1.6 TDI aircon not working
    108 Post(s)
    1816 Post(s)
    PM me your reg number and I will give you the part number.
  8. Re: Mk 6 golf 1.6 TDI aircon not working
    Mar 2012
    birmingham
    Fg60hzf bought one off eBay 150 new
  1. Aircon not working
    By dean warren in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-06-2017, 01:01 PM
  2. Aircon not working 02 Tdi Awx
    By MrPassat02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-06-2017, 08:36 AM
  3. Aircon not working
    By bear1987 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-04-2016, 01:01 PM
  4. Question A4 Cab V6 TDI Aircon not working
    By Invictagunner in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-04-2011, 08:59 AM
  5. A4 B6 Aircon not working
    By gavsman in forum VCDS - Help Requests
    Last Post: 20-04-2011, 01:45 PM
