Thread: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    #11
    Aug 2015
    Bexleyheath
    I bet that must have let you puzzled after the message appeared the second time. I am thinking that maybe as they tried to make the summer wheel loose, they had to give it a wobble and maybe that damaged the bearing or the reluctor ring for the abs. I will mention it in the garage. Thank you for the advice.
  2. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    #12
    Aug 2015
    Bexleyheath
    Hi Guys, so it's all sorted now. It's been faulty wiring from ABS sensor to control unit. It kept tripping due to steering wheel mechanically acting on the wire. What an error. Great thanks to guys at 4rings garage who identified it.
  3. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    #13
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by bubak_here View Post
    That is great news!
  4. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    #14
    Sep 2018
    Belfast
    Hi bubak
    I have the exact same issue with my 2012 C7
    even the intermittent error which has not been fixed by 2 different garages... very frustrating - plus my ABS is not working which I found out yesterday - so quite urgently need this fixed.
    do you recall did they change the cable and if so, was that the fix?
    any other info that I can pass on to the mechanic would be really helpful and appreciated.
    cheers
  5. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    #15
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by A6C72012 View Post
    Hi bubak
    cheers
    It can be one of the ABS sensors . Did they do vcds scan? It would tell you exactly which one failed.
    current: 2019 A6 S-Line 40 TDI Avant (de-chromed)
    sold: 2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  6. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    #16
    Sep 2018
    Belfast
    Thanks for the reply. I have no idea what that is but I will ask. They were not Audi specialists so maybe do not have the right equipment.
  7. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    #17
    Jun 2015
    Ireland
    69 Post(s)
    VCDS is a diagnostic tool made by ross-tech. There might be someone on this forum who is in your area and could do the scan for you. I’m in Ireland if that helps
  1. Noisy rear brake calliper (electronic parking brake)
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-08-2016, 06:41 PM
  2. Please Help Two questions - hl brake light & side light errors
    By rosso rocket in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-07-2013, 05:27 PM
  3. ABS, Parking Brake, Squeeking brakes and brake lights!
    By medvwb6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2011, 05:35 PM
  4. 2004 Golf Mk4 1.4 Match - Misfire & Brake Switch Errors.
    By mlilburn in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2009, 08:45 AM
  5. Tmps ???
    By johnvw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-10-2009, 07:16 PM
