Thread: Aircon Pressure Switch Replacement
  1. Aircon Pressure Switch Replacement
    Malvern
    8 Post(s)
    I need to replace this pressure switch on the aircon rad of my 2008 s Line.
    I bought a genuine one from the dealer together with a new o ring.
    When I unscrewed the old pressure switch the old o ring came off with it.
    I have changed one of these before on my B6 but am a bit puzzled as to how to fit the o ring
    before screwing the new switch onto the threaded part containing the Schrader valve.
    It looks to me as if I should slide the o ring over the threads so that it sits at the base of the threads
    and when the switch body reaches it, the o ring is compressed by the smooth tube below the female threaded
    part of the switch.
    Is that the correct approach?
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    A4 B6 130 (6) Avant 2003(Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013
  2. Re: Aircon Pressure Switch Replacement
    Oct 2012
    Estonia
    64 Post(s)
    Yes, slide o ring first and sensor(5Nm, does not matter but) after!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Aircon Pressure Switch Replacement
    Malvern
    8 Post(s)
    Thanks Gunnar. That reassured me enough to go for a re-gas which successfully revived the system so I now have a cool car again.
    I'm still puzzled as to why the gas was lost in changing the pressure sensor but assume that maybe it can happen in removing the old sensor.
    Lotus Elan SE 1991
  4. Re: Aircon Pressure Switch Replacement
    Oct 2012
    Estonia
    64 Post(s)
    You probably lost gas/pressure already when old sensor was still attached, I had same puzzle...but faulty G395 leaks, valve should close very quick if removing(if not in slow motion) old one.
    1 1 0
  5. Re: Aircon Pressure Switch Replacement
    Malvern
    8 Post(s)
    Good point. That is probably what happened.
    Lotus Elan SE 1991
  1. Window switch, aircon, recirculation, demister switch and parking sensor not working
    By masterinengland in forum Touran - Sharan - Caravelle
    Last Post: 18-10-2015, 08:14 PM
  2. Aircon pressure switch
    By The gaffer in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2013, 03:13 PM
  3. Aircon High Pressure Switch Replacement
    By jim_tdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-08-2011, 12:32 PM
  4. how to switch off auto aircon?
    By 2003amir in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-07-2009, 08:15 PM
  5. aircon wheres the switch?
    By t4olga in forum The Commercial Range
    Last Post: 11-01-2008, 09:08 AM
