Thread: Audi Q7 2011 - fuel injector leak
  1. Audi Q7 2011 - fuel injector leak
    Jul 2016
    Leeds
    I took my q7 to audi for a health check and they gave the following advice regarding the injectors? Surely do not need to replace all if one is leaking???
    The following items are flagged for immediate attention (red):
    There is a combustion noise from engine when ticking over and an oil loss around cylinder 5 in the vehicle cylinder head - suspect injector loose in head causing oil loss and exhaust gas escaping. This would require new seals and all 6 injectors to be done. I have also attached two images which the technician has provided in regards to this.
    Is this typical of an audi garage to do this?
    I have also attached a picture
    Any advice would be great
    Thanks in advance
  2. Re: Audi Q7 2011 - fuel injector leak
    Pembrokeshire
    22 Post(s)
    well, if one has gone, are the others going to follow ? you dont know, neither does the garage, so by doing all 6 you are guaranteeing you wont be going back for the same job to be done on the others , and some people would then kick off and argue that they all should have been done in the first place.
  3. Re: Audi Q7 2011 - fuel injector leak
    46 Post(s)
    Moved to 'Q7'
  4. Re: Audi Q7 2011 - fuel injector leak
    Apr 2017
    wirral
    hi so its a loose injector ,why would you have to do all of them ,i had the same problem and replaced number 5 injector washer and o rings ,oh and injector stretch bolt ,sorted
  1. 2011 Sharan SEL - Water Leak
    By 2011Sharan in forum Touran - Sharan - Caravelle
    Last Post: 19-11-2014, 02:55 PM
  2. Audi A4 Diesel Fuel Pump leak - AFN engine
    By chris_miller in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2014, 10:06 PM
  3. 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
    By white.akita in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2012, 09:46 PM
  4. Question 94-TDI Fuel leak around injector pump?
    By Timk in forum 80 - 90
    Last Post: 03-08-2009, 06:30 PM
  5. temp gauge water leak, fuel leak all sorted
    By a6rom in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-02-2009, 12:44 PM
