Thread: VW Golf MK5 1.9 TDI BKC engine Thermostat
  1. VW Golf MK5 1.9 TDI BKC engine Thermostat
    Mar 2016
    Northampton
    Hello All,
    Just started off with a Golf after having ford focus for for a couple of years. Yay
    My golf car temperature has an issue which is that on a town run (keeping speed low ~30 mph). The temperature needle is set to 90 degree and its all fine.
    When I take it on a highway or a motorway, the temperature sets back to about 60 - 70 degrees, that's doing almost 80 mph for about 20 odd minutes.*
    I have replaced the thermostat sensor but that did not seem to do much help.*
    I have had a look online and tried to check on how to replace the thermostat (having done it on my focus in the past), it can not be that hard.
    When I looked into it to remove the alternator in order to access the thermostat, there is a pipe which I cannot seem to remove and it is made of plastic (I was scared to put any force on it as it might break).*
    Does anyone know what that pipe is (sits on top of the alternator) and how to remove it. I have added the picture, it is in the red square, the yellow ones are the screws which I already removed but there is still something holding the pipe. Please see the image
    Thank you for reading, even the pipe name can be useful as there are not much tutorials for a BKC engine.
  2. Re: VW Golf MK5 1.9 TDI BKC engine Thermostat
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    That pipe is the boost air pipe from intercooler up to the engine egr valve (thing with the flying saucer and small black hose) and air intake manifold. to remove that pipe you need to pry out the silver spring horseshoe clip at the connection next to the alternator and a similar connection down stream of that to the right of the dipstick tube. You then replace those clips in the slots so when the pipe is refitted it snaps into place.
  3. Re: VW Golf MK5 1.9 TDI BKC engine Thermostat
    Mar 2016
    Northampton
    Quote Originally Posted by Rob69 View Post
    Thanks, I will look at it when i am with the car. I hace replaced the egr valve on this car so I can get a few bits and pieces to move out. I will check it and update you. Thanks
  4. Re: VW Golf MK5 1.9 TDI BKC engine Thermostat
    Mar 2016
    Northampton
    Thank you man, this was it. Completed the thermostat replacement and the car is fine now.
    Just one thing, if anyone is coming across this thread, there is one screw which needs to be removed before the pipe can move and it is next to tge horseshoe clip. Just be a little careful with it.
    1 2 0
  1. 2.0l ATL engine thermostat
    By bower in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2014, 10:03 AM
  2. Thermostat AKE engine
    By TOnyt-5 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2011, 10:58 AM
  3. Question Engine Thermostat
    By kasper1287 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-12-2009, 12:12 AM
  4. Please Help Find Thermostat on Engine
    By gtflyrob in forum Golf MK3 - 1993 - 1999
    Last Post: 29-06-2009, 09:52 AM
  5. Question Engine cooling thermostat
    By lamont7615 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-04-2009, 08:34 AM
