Thread: allroad 2.5 tdi quattro 2005 expansion tank
Results 1 to 10 of 11
  1. allroad 2.5 tdi quattro 2005 expansion tank
    bristol
    10 Post(s)
    Noticed some hairline cracks in my expansion tank
    Seems a good idea to replace this. Having fun though finding a replacement.
    Part is 4B0121403
    No one seems to have this tank, is it a main dealer only ? I was supplied with the wrong tank from a site on ebay. Mine has one outlet at 180 degrees below and one outlet on the top
  2. Re: allroad 2.5 tdi quattro 2005 expansion tank
    Sep 2012
    Fife
    Hi there
    I had the same problem with my A6 Avant 2.5TDi recently. I bet you got a tank for a 4 cylinder car which only has 2 pipe connections & not the 3 that the V6 needs. I got a replacement from EuroCarParts for under £15 using their weekend discount. Normal price was around £22.
  3. Re: allroad 2.5 tdi quattro 2005 expansion tank
    1837 Post(s)
    £20 for a ******* piece of crap off of fleaBay or £36.90 for a new one from Audi, noone makes and aftermarket version.
    0 2 0
  4. Re: allroad 2.5 tdi quattro 2005 expansion tank
    bristol
    10 Post(s)
    Searched hi and low , it seems to be a main dealer part only
    Picking one up from audi tomorrow for £36
    Expect the tank would be fine, but not worth taking the risk
  5. Re: allroad 2.5 tdi quattro 2005 expansion tank
    1837 Post(s)
    I put the number into Tec Doc and it said no, that is usually pretty conclusive and no further checking will help.
  6. Re: allroad 2.5 tdi quattro 2005 expansion tank
    Sep 2012
    Fife
    I didn't use fleabay but my (relatively) local ECP as my tank was leaking & I needed my car back on the road ASAP. Tank is made by Topran so I have no idea of quality relative to genuine part but I will keep an eye on it just in case. Apologies if I caused any offence by not buying a genuine part......
  7. Re: allroad 2.5 tdi quattro 2005 expansion tank
    1837 Post(s)
    Doc, we overlapped as your post wasn't there when I opened the thread so it wasn't aimed at you.
  8. Re: allroad 2.5 tdi quattro 2005 expansion tank
    bristol
    10 Post(s)
    All fitted with new tank cap. G12 coolant refresh, looks good.
    Cars nearley up together now where i would like it to be. Only issue left is a very slight rough start from cold for a second or two. I am sure its sucking in a tiny bit of air somewhere. Think i will wait until it gets colder to investigate.
    New plugs / starter / battery has improved her a great deal along with a terraclean.
  9. Re: allroad 2.5 tdi quattro 2005 expansion tank
    May 2017
    Middlesbrough
    Hey I notice you mention Terraclean - did it make any difference? I was thinking about getting my done as its not as good on fuel and power as I was expecting and wondered if this might sort it out?
  10. Re: allroad 2.5 tdi quattro 2005 expansion tank
    bristol
    10 Post(s)
    I removed the egr and had it remapped. For the same price i had the power taken to 217 bhp ( i dont drive it hard)
    Also the garage i use carried out the terraclean the same time.
    Runs very smoothly , also picks up very well. Seems to get through the gears quicker, could do with the a 6th gear !
    Have not noticed improvement with mpg figures
  1. Allroad Coolant Expansion Tank - 2.5 TDI AKE
    By allan_audi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-05-2014, 04:18 PM
  2. Question oil in expansion tank
    By rossco.ross in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2012, 11:59 AM
  3. Question Expansion Tank
    By m50yre in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-07-2011, 04:07 PM
  4. Oil in expansion tank
    By joeynicholls in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-05-2011, 09:48 AM
  5. Expansion Tank
    By TERRYDOO7 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2009, 05:19 PM
