Thread: Brakes pulling to one side after front disc and pads replacement
Results 1 to 10 of 12
  1. Brakes pulling to one side after front disc and pads replacement
    Jun 2008
    Western Europe
    Anyone have any ideas on the above problem?
    My trusty B7 has given me 9 years loyal service but recently I braked hard on the motorway and warped the discs
    It was on its original front discs so needed replacing anyway.Rear discs were replaced last year.
    So bought the parts and left them to a local mechanic to be fitted.
    On the way home after collecting the car noticed it was pulling to the left under braking.
    Rang the garage who said I may have a bad caliper or they just need bedding in.
    I'm not convinced its either of these things,so any advice appreciated.
    Taking it on a long trip tomorrow so that should rule out the bedding in theory..
  2. Re: Brakes pulling to one side after front disc and pads replacement
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Hopefully they fitted new pads with the new discs, in which case there is no real 'bedding in' required as the braking surfaces are nice and flat and already making perfect contact. Hopefully they also cleaned up the rust and scale from the pad carrier brackets while they were off to change the discs, allowing the pads to travel up to the disc surface without binding or jamming. Also the calipers should float freely on the pins, allowing them to apply equal pressure to both pads each side of the disc. If I was you I'd jack and support the front end take the wheels off, carefully run the engine ( in neutral obviously) to get servo operating and get someone to press the pedal and see what is going on with the caliper and pads.
  3. Re: Brakes pulling to one side after front disc and pads replacement
    Sep 2008
    6 Post(s)
    You can rule out a sticky piston by driving the car and coasting to a stop without using the brakes. If the disc is hot, then there's your problem. Wouldn't be the first time I've seen a brake change where brake slider pins haven't been lubed. I use Lockheed red grease.
    Only real way to check is a proper brake dismantle and inspection, especially the piston boot. Any sign of the rubber dust sleeve being twisted or cut then you could have water ingress and corrosion. Bigg Red make rebuild kits assuming the piston is still salvageable.
    Regards warped discs, I've seen brake pad transfer rather than warped discs. To bed in new discs and pads for first 200-300 miles, get car up to speed then brake hard but don't come to a complete stop and remove your foot from the brake to free-wheel. Check there's no contamination or heat spots on the discs periodically.
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  4. Re: Brakes pulling to one side after front disc and pads replacement
    108 Post(s)
    1816 Post(s)
    What make of parts?
  5. Re: Brakes pulling to one side after front disc and pads replacement
    Jun 2008
    Western Europe
    Thanks for the replies @Rob69 They changed the pads along with the discs,they said they cleaned the slides as well. @spartacus I will try that test,don't think I will have time to dismantle it all again though.You may be right that the discs weren't warped, but with their age and 97k of mostly city driving they probably needed
    replacing anyway. @Crasher The discs and pads were Apec.
    After 150 miles they seem to have improved,but then I've had my kids in the car for all of that time so couldn't give them a real testing. Erratic driving usually leads to vomiting from my unfortunate experience.
    I checked the last 2 mot reports and they both show a brake imbalance on the front axle of 4% this year and 9% last year.Both times the left wheel was the stronger one which would make sense with pulling to the left.
    I think I will leave it for now,the only annoying part was the garage tried to mask the problem by inflating the left tyre to a higher pressure than the right to offset the brake pull.
    Thanks all
  6. Re: Brakes pulling to one side after front disc and pads replacement
    108 Post(s)
    1816 Post(s)
    Quote Originally Posted by mcmolloy View Post
    A customers car (A3 2L TFSI quattro) came in a few months back with one of the problems being the front brakes were snatching and pulling, APEC. We fitted Pagid, sorted. A local factor came in the other week trying to get me to buy that crap and as it was a lady, I said no politely.
  7. Re: Brakes pulling to one side after front disc and pads replacement
    Jun 2008
    Western Europe
    Ok thanks Crasher, had a quick google before I bought and didn't see anything scary about them, but you live and learn.
    Just noticed today when reversing out of my drive the brakes made a 'clunking' sound.A Renault I owned years back used to make the same sound,I think it was because the pads didn't fit
    perfectly in the holders. Anyways...
  8. Re: Brakes pulling to one side after front disc and pads replacement
    Pembrokeshire
    22 Post(s)
    got some jap truck thing in, toybota hilix surf or something, its funny.. rear brakes i fitted customers own supplied shoes about 6 months ago. took the drums off, the linings fell off. oh well, plus the front pads he fitted dont pull up straight, no idea what make they are..
  9. Re: Brakes pulling to one side after front disc and pads replacement
    108 Post(s)
    1816 Post(s)
    a 'clunking' sound
    Yes forgot to say, they did that as well.
  10. Re: Brakes pulling to one side after front disc and pads replacement
    Nov 2010
    104 Post(s)
    Must admit I've never heard of APEC, but their website looks pretty flashy, you never know where most replacement parts are getting made these days ! I'm not sure any garage would play around with tyre pressures to try and hide a braking problem though. You admit yourself the O/S brake performance has been deteriorating over the past few years according to the MOT.
  1. What replacement disc's & pads
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-11-2015, 11:01 PM
  2. Replacement disc brakes
    By mickel2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-02-2012, 11:45 PM
  3. tdi front disc and pads
    By markspark71 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-03-2009, 12:28 AM
  4. Replacement RS6 disc and pads
    By pbere in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-12-2008, 08:37 PM
  5. Front pads and disc?
    By A6_JAck in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-08-2008, 08:14 AM
