Thread: Passat 2.0tdi dsg 170 starting problems from cold
Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 84
  1. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #71
    Mar 2012
    birmingham
    Thanks for explaining how to do it anyway
  2. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #72
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    No problem. I remember the first time I tackled a head gasket change on a car - frightened me to death that I might not be able to put it back together.
    Mad Mitch
  3. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #73
    Mar 2012
    birmingham
    Just spoke to vw they said there's only 1 coolant temp i mentioned about the coolant temp under the tandem pump and they didn't know
  4. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #74
    Jan 2012
    10 Post(s)
    87 Post(s)
    And how many of them do you think have actually stripped a 2.0 litre tdi engine down and examined all of the parts for wear and tear instead of looking at a computer telling them what to undo, replace and do up again? It's there because I have seen it with my own eyes having stripped mine down with the only thing I haven't seen being the inside of my DSG box.
    You can see it inside the flange picture above.
    Mad Mitch
  5. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #75
    Mar 2012
    birmingham
    Ok I've booked it in the garage now to have that sensor replaced ,I asked the guy on the parts counter and said he wasn't aware of a tcs being behind the alternator his aware of the one under the tandem pump ?
  6. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #76
    Jan 2012
    10 Post(s)
    87 Post(s)
    Yes there's one there on the thermostat flange as well not quite behind but slightly to the right of the alternator at the front of the engine.
    Mad Mitch
  7. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #77
    Mar 2012
    birmingham
    Thanks for the PDF did help a lot ,took the car for the cambelt change as it was due and a couple days later the engine is hunting Miss fires a couple of times ,so I checked the diesel filter and its black and the diesel is black ,is that the tandem pump gone again
  8. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #78
    Jan 2012
    10 Post(s)
    87 Post(s)
    Quite possibly as that's normally a sign and there's not much else that will add oil into the fuel system.
    If the car is misfiring it may be that the timing needs to be adjusted as the valve timing may not be where it should be after the belt change but it could also be something else related to the injectors. I always check the injector "lash" after a timing belt change. The lash is the distance the injector piston plunger needs to be from bottoming out inside the chamber. It is set by undoing the locking nut on each of the threaded adjusters in the rocker fingers then setting each cylinder in turn to its lowest point of the stroke, followed by screwing the adjuster down until it stops abruptly thus bottoming the piston plunger in the injector fuel chamber, then backing off the adjustment by 180° degrees (which stops the plunger from hitting the bottom each time it is compressed by the rocker finger) and finally locking the position with the lock nut.
    Mad Mitch
  9. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #79
    Mar 2012
    birmingham
    Not misfiring all the time just now and again and occasional black smoke never ever did that before I'll get a new tandem pump,never known a car with so many faults
  10. Re: Passat 2.0tdi dsg 170 starting problems from cold
    #80
    Jan 2012
    10 Post(s)
    87 Post(s)
    More often it's the external gasket that has failed or the bolts not tight enough (the bottom one is a pig to do up and torquing nigh on impossible with the coolant hoses on). Would do a gasket change, fuel filter change and clean up first as it's the cheapest option. There will be oil in the system for a while so add a can of Liquid Moly Diesel Purge to a tank of fuel which will help flush it whilst cleaning the injection system. Renew the fuel filter after a few thousand. I put one in every 6000 miles now as they are sub £10 and always have spares as I buy 2 or 3 of each filter at a time.
    Mad Mitch
  1. Passat 2.0tdi 2007 170 dsg hesitant starting from cold
    By scanny in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-07-2016, 06:52 PM
  2. A3 2.0tdi 140 poor cold starting
    By Scottm88 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-08-2014, 11:39 AM
  3. Cold Starting Problems
    By Boltupright in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-08-2010, 11:17 AM
  4. Please Help problems starting from cold
    By omore2000 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-08-2009, 04:42 PM
  5. Cold Starting problems
    By shabazmo in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-06-2008, 08:50 PM
