Thread: 17519 02 sensor regulation bank 1 system tioo lean P1111
Page 1 of 3 123 LastLast
Results 1 to 10 of 56
  1. 17519 02 sensor regulation bank 1 system tioo lean P1111
    Dec 2013
    BRACKNELL UK
    Hi I hope someone can help me on this forum. I have a 2004 Polo 1.4 petrol BKY engine with this code, I have changed the MAP, cant find any air leaks. I have been told it could be the EGR valve, or the air fuel wide band 02 sensor, I am quite new to diagnostics, and I have a snap on verus, Can someone help me to diagnose the problem.
    I thought a possible fuel pressure, but the code says it is Lean, and I have shed loads of black soot coming out of the exhaust, the emissions on the mot went off the scale.
    Any help would be real appreciated
    Paul
  2. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    Pembrokeshire
    22 Post(s)
    so the ecu thinks its lean, so dumps loads of fuel back in to compensate.its obviously not too lean. check the switching of the lambda. would also help to see the mot results from the emissions test, see what lambda reading is.
  3. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    Dec 2013
    BRACKNELL UK
    Hi Thanks for taking the time, What do you mean by switching. open and closed loop?
    Paul
  4. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    Pembrokeshire
    22 Post(s)
    when its hot the lambda sensor will switch volts, rich lean rich lean etc, to stabilise the fuel. your snap on can do this if you find the right measuring block to go into, as you would with vcds. if it is switching them chances are the sensor is ok . but, if its stuck on lean then theres your problem. you will see the volts change between 1 and 5 or somewhere close to that, cant think without looking it up.. look at ross tech wiki to find the measuring block you need, then on the snap on go into expert mode, find measuring blocks, enter the code and see whats what.
  5. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    Dec 2013
    BRACKNELL UK
    Hi m Thats what I have been doing, banging my head against ed a brick wall, Now I find out it is a air/fuel sensor, 5 wire wide band, and they work totally different. they work on current flow and very difficult to diagnose a bad sensor
  6. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    Dec 2013
    BRACKNELL UK
    I have now checked the fuel pressure, thats ok
    pin 51 at the ecu 5 volts
    pin52 nothing
    pin70 nothing
    pin71 nothing
  7. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    1840 Post(s)
    Yes it is an NTK LZA07-V3.
    Have you checked for an air leak upstream of the sensor?
    The problem with the fault code 17519 (P1111) Oxygen sensor control; Bank 1: System too lean on a BKY is that VW don't list that code as being possible, it would be 16555 (P0171)- Fuel trim; Bank 1;System too lean so something isn't right. The VW procedure for P0171 is check fuel filter regulator and check it is the correct pressure rating of 3 Bar, test the injectors (very unlikely), test the pre cat lambda control and test the post cat lambda heating.
  8. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    Dec 2014
    Bedford
    42 Post(s)
    Check your oil filler cap seals.
  9. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    Dec 2013
    BRACKNELL UK
    Why ????????
  10. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    Dec 2014
    Bedford
    42 Post(s)
    Air leak.
  1. 008583 - Bank 1 System too Lean at Idle
    By libra007 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-03-2014, 02:34 PM
  2. Audi 1.8T Fuel Trim: Bank 1 (Mult): System too Lean
    By RedZed2009 in forum VCDS - Help Requests
    Last Post: 03-07-2010, 02:50 PM
  3. Please Help Fuel Trim: Bank 1 (Mult): System too Lean
    By Phil2112 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2009, 03:05 PM
  4. Fault code P1128- 'Long Term Fuel Trim - System Too Lean Bank 1
    By bassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-05-2008, 09:56 AM
  5. A6 1.8T Sport. Fault Code P1136 Bank 1 Long Term Fuel System Too Lean
    By anthonyjparker in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-11-2007, 03:33 PM
