Thread: 17519 02 sensor regulation bank 1 system tioo lean P1111
Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
  1. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #51
    Dec 2013
    BRACKNELL UK
    Quick up date, Still no further, it is drivingme up the wall, I took the throttle body of yesterday and gave it a good clean,I made a bung to go in to the intake, Filled it with smoke through a small holeand applied a very small amount of pressure, I cant find any leaks at all, Andit does keep the pressure for a while. so I put it all back together and drovethe car, It went great for about 5 minutes and then I went round a bend and itnearly cut out, it was really struggling to keep going, and then it graduallystarted to clear, I am putting a new fuel filter on it today, and see if thatmakes a difference. no extra codes when I got back still P1111. and stillblack soot out of the exhaust. I am now very tempted to bite the bullet and buya new 02 sensor just to take it out of the equation
  2. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #52
    Dec 2013
    BRACKNELL UK
    Just changed the fuel filter, Not driven it yet, I have cleared the codes and had a quick look at live data while engine running.
    a few more details
    Block 30-1 bank 1 sensor 1 (111)
    30-2 bank 1 sensor 2 (110)
    32-1 Lambda (add) Self adaption 0
    32-2 Lambda (Mult) Self adaption 0
    33-2 bank 1 voltage oxygen sensors 0.268
    That lambda sensor self adaption should not be at 0 ???
  3. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #53
    Dec 2013
    BRACKNELL UK
    Ok Just drove it hard, I got about 300 yards and it cuts out, I let slow down then it starts to pick up after about 50 yards, and it is ok again, So i drive of steady for about a mile, It all good, then it does it again, same thing chugs along then picks up and away we go again. Is there a pid on the verus to show if I am losing fuel pressure? I might have to connect the fuel pressure gauge and tape it to the windscreen to see if it is a fuel pressure problem, Or is there an easier way?.
  4. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #54
    Dec 2013
    BRACKNELL UK
    Today I put a fuel pressure gauge on, strapped it to the windscreen, and drove it, It started to play up aftera while but the fuel pressure was a constant 3 bar. i came back unpluged the pre cat 02 sensor and drove it again, It went great no cutting out , so i put the dianostic on live data and my injection timing is now 3ms as apposed to 6 and 7ms before. "Crasher" if you see this can you let me know what you think please,, """New Sensor" ????? £135, welll spent if it sorts the problem.
    paul
  5. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #55
    1841 Post(s)
    I would rather before fitting a new sensor, you drove it with the lambda regulation shut down in 099 and watched the lambda feedback.
  6. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #56
    Dec 2013
    BRACKNELL UK
    New sensor fitted, Now runs perfect, Run it for about 5 miles came back and no codes. Thanks for all the help from this forum, especially Crasher who has spent so much time helping me trying to sort this nightmare of a car.
    Thanks again
    Paul
  1. 008583 - Bank 1 System too Lean at Idle
    By libra007 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-03-2014, 02:34 PM
  2. Audi 1.8T Fuel Trim: Bank 1 (Mult): System too Lean
    By RedZed2009 in forum VCDS - Help Requests
    Last Post: 03-07-2010, 02:50 PM
  3. Please Help Fuel Trim: Bank 1 (Mult): System too Lean
    By Phil2112 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2009, 03:05 PM
  4. Fault code P1128- 'Long Term Fuel Trim - System Too Lean Bank 1
    By bassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-05-2008, 09:56 AM
  5. A6 1.8T Sport. Fault Code P1136 Bank 1 Long Term Fuel System Too Lean
    By anthonyjparker in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-11-2007, 03:33 PM
