Thread: 17519 02 sensor regulation bank 1 system tioo lean P1111
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 56
  1. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #41
    Dec 2013
    BRACKNELL UK
    I can't do that untill next week as I am away. Did you get the pictures, and how are you getting on with the r32?.
  2. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #42
    10 Post(s)
    186 Post(s)
    No pictures, 5 milliseconds is a lot.
    The R32 is driving me to distraction, I think the FIC unit is faulty as it will not display the lambda voltage.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  3. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #43
    Dec 2013
    BRACKNELL UK
    Just sent pics again . Let me know if you don't get them please
  4. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #44
    Dec 2013
    BRACKNELL UK
    Hi still spending a lot of time on the Internet , learning how to use my Verus, to try to find this problem, and thanks to Crasher , for the help he has given me, I still have not sorted the problem, I have cleared the codes so many times now, after trying different things, I think I need to start again with the basics, I thing I have not done is drive the car, all I have done is start it stationary, that got me thinking, where did I start, I always take pictures or fault codes, so I have gone back through my pictures of the very first code read, And I found a P1132 Lack of heated oxygen sensor 1 bank 1 switch ........ Rich, The ....... I can't see as the light was on that bit. This code has never come back up but that might be because I haven't driven the car. Does this help in diagnosing my problem.
    paul
  5. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #45
    Dec 2013
    BRACKNELL UK
    I have been looking at the fuel adaption today, at tickover the fuel adaption is 24%, if i raise the rpm nearly to open throttle, the adaption stays at 24%, but if I keep snapping the throttle it goes down to about zero and then when the engine is setteling down, it goes way negative, and then slowly back to 24% again.
    Just Few readings from my autel
    intake manifold pressure is 637.56 mbar and the spec is 240-420 this reading is at tickover
    Idle stabilization, self adaption is 10 the spec is-10-0.0%
    Lamda control is at 25% and the spec +10-10
    intake manifold pressuere is 457.2 the spec is 240-420 mbar
    does anyone have any clues, it is looking like the manifold pressure is to high.
    Crasher, have you given up on me?.
    Paul
  6. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #46
    Dec 2014
    Bedford
    31 Post(s)
    Why would it be too high? Catalyst or exhaust blockage maybe.
  7. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #47
    Dec 2013
    BRACKNELL UK
    It could be all the fuel it has been pumping for a while, Still got black soot coming out of the exhaust.
  8. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #48
    10 Post(s)
    186 Post(s)
    A post throttle body air leak would do that and such a leak would make the lambda sensor signal cause extra fuel to be added, then more and then more.
  9. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #49
    Dec 2013
    BRACKNELL UK
    so are we talking after the map, before the throttle body, Like inlet manifold, Or are we still looking any where on the vacume side, I might take the inlet manifold off today and see what I can find, I could also take the throttle body off and give it a clean, Hopfully I might find something.
    Thanks Paul
  10. Re: 17519 02 sensor regulation bank 1 system tioo lean P1111
    #50
    10 Post(s)
    186 Post(s)
    After the throttle valve plate up to the head face, anywhere on the vacuum side including the servo. I use a smoke tester for this job.
  1. 008583 - Bank 1 System too Lean at Idle
    By libra007 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-03-2014, 02:34 PM
  2. Audi 1.8T Fuel Trim: Bank 1 (Mult): System too Lean
    By RedZed2009 in forum VCDS - Help Requests
    Last Post: 03-07-2010, 02:50 PM
  3. Please Help Fuel Trim: Bank 1 (Mult): System too Lean
    By Phil2112 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2009, 03:05 PM
  4. Fault code P1128- 'Long Term Fuel Trim - System Too Lean Bank 1
    By bassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-05-2008, 09:56 AM
  5. A6 1.8T Sport. Fault Code P1136 Bank 1 Long Term Fuel System Too Lean
    By anthonyjparker in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-11-2007, 03:33 PM
