Thread: S3 8p cutting out idle help no EM lights!
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: S3 8p cutting out idle help no EM lights!
    1840 Post(s)
    A fuel filter being blocked or a failed lift pump will not cause the system pressure at the high pressure fuel pump to be too HIGH and neither will a worn pump cam follower, with those problems the pressure would be too LOW. Firstly the figures displayed in measuring blocks need to be studied and there are known issues with the G410 Low fuel pressure sender 06E 906 051 K
    004767 (P129F) - Low-Pressure Fuel Pressure Regulation: Pressure too high
    012555 (P310B) - Low Pressure Fuel regulation: Fuel Pressure: outside Specification
    018972 (P2540) - Low Pressure fuel sensor - Range/Performance
  2. Re: S3 8p cutting out idle help no EM lights!
    Oct 2010
    Essex
    Thanks so wherre do i go from here?
  3. Re: S3 8p cutting out idle help no EM lights!
    Oct 2010
    Essex
    Its p2540 not 2450?
  4. Re: S3 8p cutting out idle help no EM lights!
    1840 Post(s)
    I have changed that code, as I said the measuring blocks need to be studied by someone with the equipment and the knowledge to understand what is going on, barking at fault codes often leads to wasted money.
  5. Re: S3 8p cutting out idle help no EM lights!
    Oct 2010
    Essex
    I dont know anyone with the equipment and need to use the car but dont want to so im stuck?!
  6. Re: S3 8p cutting out idle help no EM lights!
    1840 Post(s)
    Take it to a VAG specialist or an Audi dealer. You can't expect people to tell you what to replace based on a single code read of codes that SHOULD make the engine management light come on and on a modified car, it could be anything BUT it is likely to be the G410 sensor as it is a known problem with those fault codes.
  1. Cutting out stable idle
    By tooter in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2016, 08:20 AM
  2. A6 2.4 V6 irratic idle and cutting out
    By if11677 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 07-11-2012, 03:18 PM
  3. Please Help B5 A4 1.8si irratic idle and cutting out
    By diesel.5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-02-2010, 10:02 PM
  4. Please Help 1.4 16v Cutting Out on idle
    By eddieshittygolf in forum Golf MK4 - 1999 - 2004
    Last Post: 20-11-2009, 05:51 PM
  5. Eratic Idle and cutting out - HELP!
    By Lucky in forum Golf MK4 - 1999 - 2004
    Last Post: 08-03-2008, 10:26 AM
