Thread: 170brd avant 57plate engine oil contamination in the fuel tank
  1. 170brd avant 57plate engine oil contamination in the fuel tank
    Jul 2008
    hi going to be replacing the injector seals in my audi as have found oil in the fuel tank
    I had the injectors replaced around 3 years ago by audi uk after one failed on autoban going through Germany and car cut out .
    cars been a nightmare for last few years as no one got to the bottom of the problem before ... white/blue smoke erratic idle
    does anyone have a guide for removing the fuel tank to clean it out ( was planning on rinsing it out with clean diesel ) or is there something to add to tank to break up the oil contamination whilst in the car without damaging anything in tank
    any help/advice much appreciated
    thanks Stephen
  2. Re: 170brd avant 57plate engine oil contamination in the fuel tank
    Pembrokeshire
    22 Post(s)
    tandem pump..
  1. cant find fuel tank sender 2003 A6 C5 Avant 1.9 Tdi
    By corrado999 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-03-2015, 09:18 PM
  2. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  3. what can cause oil to go into fuel tank and fuel in sump ( blb engine )
    By imi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-04-2013, 08:44 PM
  4. Question What is the fuel tank capacity of an A4 Avant 1.9 TDI Quattro?
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-01-2010, 04:44 AM
  5. A6 Avant 2.5 tdi 1999 Fuel tank
    By mhobson in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-01-2008, 12:58 PM
